Re: E-85, how long can it sit in carb.
[Re: 70blackfish]
#971736
04/12/11 12:39 AM
04/12/11 12:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
if running E-85 and not running your car for a month or two. will e-85 go bad and or start eating parts? rubber lines, gaskets?
It will go bad... it will absorb water... water is what hurts the carb(that causes corrosion on the bare alum parts)... wont bother rubber like meth... alot of the carb place put a different gasket on them but I dont know if its the gasket issue or hole sizes are different... I have left it in my carb over the winter and did see a little corrosion the second year so now I run gas in the system for the winter
[Re: ajcasini]
#971740
04/12/11 08:32 PM
04/12/11 08:32 PM
MR_P_BODY
As long as you have a good sealed fuel system that will not allow moisture you are fine. I never draind the bowls in my carb all season and never saw a problem. Took the carb apart at the end of the season to fix a leak and all looked brand new. My friend who runs one of my carbs left fuel in his all summer and winter and brought the carb over to me to look at, and looked like the day I put it together.
I would not worry about it on a week over week basis like Methanol but I would drain it over the winter. I used to do it on race gas too. If you do leave it in I would at least fire the car and warm it once a month while being stored if you can.
You have 2 vents on the carb and a vent on the tank... how can you have a good sealed system
[Re: MR_P_BODY]
#971741
04/12/11 10:48 PM
04/12/11 10:48 PM
Posts: 1,436 Oklahoma City OK
Cudajon
Oklahoma City OK
According to Popular Mechanix article on E15 - E85 it can go bad in less than a month or last for a year it all depends on the temp, humidity, and luck, and there is no additive currently on the market that wiil prevent it. Its why everybodys weed eater, chain saw, lawn mower, etc are having their carbs trashed over winter. Pop Mech article.
[Re: Cudajon]
#971742
04/12/11 11:06 PM
04/12/11 11:06 PM
MR_P_BODY
The only way to keep it for prolonged periods of time is to keep it in sealed drums... we got it in steel drums at work and I would store it for over a year until I/we needed it for testing.... I store it here in the pole barn for 5 months(over the fall and winter) in steel drums
[Re: Cudajon]
#971744
04/12/11 11:25 PM
04/12/11 11:25 PM
MR_P_BODY
There's gotta be someway to store it r the filling stations would be having a fit, however, there has been some cases of people fillin up at a station and it killin their car. Coincidence?
Filling stations have vents also but they use smaller tanks(usually 2000 to 5000 gal tanks) but they move the fuel quick enough so it doesnt sit around in the tank... a production car has a sealed system(injected) and has a vent/vac cap and a shut off on the vent (all for emissions)... the cap can allow enough vac or pressure to move but the vent opens for normal driving Also the stations are SUPPOSE to check their tanks for water on a regular basis
[Re: Jeremiah]
#971746
04/13/11 12:22 AM
04/13/11 12:22 AM
MR_P_BODY
My experience from several years ago...
edit: the pic is from last summer when I finally pulled the carb apart to see why is was running like an edelbrock 750.
The anodized metering block do help... wish I could get the whole thing anodized
[Re: Cudajon]
#971747
04/13/11 09:44 AM
04/13/11 09:44 AM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
I guess I must be living right. Never have had a problem on my weedeater, mower, tiller, or anything. Even after they set for 2 years. One or two pulls and they run......blame it on something other then E10.
I will have to take my E85 carb apart, its set for almost two years now. Wouldn't run when I tried it last spring. I hope I have time to mess with it this year.
M<ichael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
[Re: Jeremiah]
#971751
04/13/11 01:49 PM
04/13/11 01:49 PM
MR_P_BODY
In my situation I was running E-85 for the summer and ran a tank or two of 110 Sunoco through the car before storing it for three years. I have seen power valves that sat in empty carbs rust a little but never corrode like the picture shows.
The thing with your PV... that corrosion is not on the fuel side... I dont know what was attacking them other than moisture
