LCA/Pivot question??... #971622
04/11/11 10:47 PM
04/11/11 10:47 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
I was getting my parts ready to put the front suspension on this weekend and noticed that my pivot pin was not all the way in like the other LCA.
I need verification that the pin should be pressed all the way to the collar. See pics..
Thnx Chuck
Re: LCA/Pivot question??... [Re: moparrulzzz] #971623
04/11/11 11:08 PM
04/11/11 11:08 PM
BDW Online content
BDW  Online Content
Absolutely needs fixing. When I did mine, they pressed pin into bushing, then pressed into LCA.
Check step 14
http://www.moparmusclemagazine.com/tipstricks/155_0306_control_arms/index2.html
Re: LCA/Pivot question??... [Re: BDW] #971624
04/12/11 01:08 AM
04/12/11 01:08 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Bottom pic is correct. The top pic shows the inner sleeve on the bushing has been pressed out the back side..........That bushing needs to be replaced properly.
Re: LCA/Pivot question??... [Re: Jim_Lusk] #971625
04/12/11 01:12 AM
04/12/11 01:12 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I agree with Jim....
The magazine article referenced above does show the bushing fully installed & it still exposes the stepped shoulder...
Re: LCA/Pivot question??... [Re: 1_WILD_RT] #971626
04/12/11 06:25 AM
04/12/11 06:25 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Totally agree. That pin is stepped and the bottom pic is right. I've done at least 4 sets and they all looked like the bottom pic when done. Pressed pin into bushing then pin/bushing assembly into LCA.
Re: LCA/Pivot question??... [Re: Jim_Lusk] #971627
04/12/11 10:28 PM
04/12/11 10:28 PM
Mansfield,Ohio
Mansfield,Ohio
Ok so the top pic the pin/inner sleeve has been pressed to far?
If the inner sleeve has been pressed thru as well you can't press it back it needs to be replaced?
Re: LCA/Pivot question??... [Re: moparrulzzz] #971628
04/12/11 10:37 PM
04/12/11 10:37 PM
Mansfield,Ohio
Mansfield,Ohio
Is there a easier way to remove the bushings besides melting the rubber and a air chisel?
Any suggestions?
Thnx
Re: LCA/Pivot question??... [Re: moparrulzzz] #971629
04/13/11 12:21 AM
04/13/11 12:21 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Press out the pin again and use a screwdriver to pry the rubber out. Then weld a washer to inside of the outer sleeve and press it out. Open the jaws of a vise to about 2/3 the size of the inner sleeve. Take a 3lb sledge and hit the inner sleeve against the vise jaws while rotating the pin. After several blows the sleeve will slide off.
Re: LCA/Pivot question??... [Re: Jim_Lusk] #971630
04/13/11 02:42 PM
04/13/11 02:42 PM
Canada
Dons Dart Offline
Dons Dart  Offline
Canada
I cant believe I saw that another idiot in the world.I took my lowers in to have the bushings pressed in and even gave the idiot paper instructions,he still pressed the same to far in.Took my new bushings witch the idiot had to pay for and had the job done right.good luck.
Re: LCA/Pivot question??... [Re: Dons Dart] #971631
04/13/11 03:06 PM
04/13/11 03:06 PM
Belle Mead, NJ
65Frank Offline
super street
65Frank  Offline
super street
Belle Mead, NJ
I know it might seem like overkill, but I bought a $199 Harbor Freight 20-ton press that I've used not only for LCAs but rear axle bearings and trans bearings. To me it's money well spent to avoid this kind of aggravation.
Re: LCA/Pivot question??... [Re: 65Frank] #971632
04/13/11 04:08 PM
04/13/11 04:08 PM
Holly/MI
Holly/MI
I got a $99 12 ton press back in 1987. Have done countless trans, axle and suspension bushings and bearings for myself and friends. Not to mention it will hold parts for you while you torch or beat on them better than your biggest friend can. Great investment.
Re: LCA/Pivot question??... [Re: Dean_Kuzluzski] #971633
04/13/11 11:28 PM
04/13/11 11:28 PM
Mansfield,Ohio
Mansfield,Ohio
Thnx guys, getting a press is in the future!!
I sure hope the welded washer tip works, that would make things alot easier!!
