1971 GTX Fender tag Question V7W and V8W Help! #971495
04/11/11 09:02 PM
04/11/11 09:02 PM
Lexington, Kentucky
lawnmanlex Offline OP
Lexington, Kentucky
I purchased a 1971 GTX last year that was original everything with two fender tags. It is red with white vinyl top and white interior it also has two codes on the fender tag that denote white striping. Can anyone please tell me what I should put back on the car. I can send the full fender tag info to anyone if you like. The two codes are V7W and V8W but the whole problem is that it is a N96 Air Grabber car. I know that the fender tags are the original tags and they are not fake. I can send pics to anyone that will help. The car is leaving the body shop in about three weeks and I just wanna get the car right with the correct striping. I have small parts of the build sheet but they are in a million pieces due to a rats nest being built in the seat. Please help its almost spring!
Chris
Re: 1971 GTX Fender tag Question V7W and V8W Help! [Re: lawnmanlex] #971496
04/11/11 10:52 PM
04/11/11 10:52 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
The V7W is the pin stripe. White in this case. All 71 GTXs came with the pin stripe, although most seem to be omitted during restoration.
The V8W and N96 are mutually exclusive on a 71 GTX. It's one or the other. That just doesn't add up.
Post the tag pic.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 1971 GTX Fender tag Question V7W and V8W Help! [Re: 471Magnum] #971497
04/11/11 11:39 PM
04/11/11 11:39 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
See the stripe info at http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1971/71_Satellite_33.jpg
S is Standard & E is extra cost. I do not see that either stripe has anything to do with the hood.
Re: 1971 GTX Fender tag Question V7W and V8W Help! [Re: Alaskan_TA] #971498
04/11/11 11:43 PM
04/11/11 11:43 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I see it now, black only, no white.
What is the code for the bumper / valance stripes?
Re: 1971 GTX Fender tag Question V7W and V8W Help! [Re: Alaskan_TA] #971499
04/12/11 01:20 AM
04/12/11 01:20 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
V8W is a legitimate code as well as V8X and V8Y.
Here's a great site
71 Satellite stripes.
Barry. I think you are asking about M75. That's the code for the bumper/valence stripes. On a GTX, V8* is the fender/tank track stripe.
Are you thinking V8* striping was not available with N96? Is that what you are getting at?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 1971 GTX Fender tag Question V7W and V8W Help! [Re: 69CoronetRT] #971500
04/12/11 07:43 AM
04/12/11 07:43 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
The V8* stripe was not available with the N96 hood (on a GTX). If the fender tag has both codes, something is amiss.
Note that on a Roadrunner, the V8* stripe is the C-pillar stripe. You could get it with the Air Grabber.
-Jim
Re: 1971 GTX Fender tag Question V7W and V8W Help! [Re: 471Magnum] #971501
04/12/11 09:18 AM
04/12/11 09:18 AM
Lexington, Kentucky
Lexington, Kentucky
I'll post a pic of the fender tag and let you guys see it. Its a white vinyl roof car too
Chris
Thanks!
Re: 1971 GTX Fender tag Question V7W and V8W Help! [Re: lawnmanlex] #971502
04/13/11 12:08 AM
04/13/11 12:08 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
this survivor GTX is also N96 V1X V7X V8X ??
Re: 1971 GTX Fender tag Question V7W and V8W Help! [Re: 6bblgt] #971503
04/13/11 12:35 AM
04/13/11 12:35 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I'll "assume" we are talking St. Louis assembled '71 GTXs
found another (color changed):
928-spd N96 V1X V7X V8X "sunroof"
Re: 1971 GTX Fender tag Question V7W and V8W Help! [Re: 6bblgt] #971504
04/13/11 12:40 AM
04/13/11 12:40 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Might just be a code quirk.
Bottom line though is that you can't have the stripe AND the Air Grabber. Well I guess you COULD, but it would sure look dorky.
-Jim
Re: 1971 GTX Fender tag Question V7W and V8W Help! [Re: 471Magnum] #971505
04/13/11 12:47 AM
04/13/11 12:47 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
I wonder if thats the code for the blacked out area behind the fiberglas a/g buble on the vent part of the hood? sort of like the roadrunner decor package? just a guess..
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 1971 GTX Fender tag Question V7W and V8W Help! [Re: 6bblgt] #971506
04/21/11 01:13 AM
04/21/11 01:13 AM
Lexington, Kentucky
Lexington, Kentucky
Hey man thanks for the help... What do you suppose I should put back on the car then? its a numbers car with the original fender tag and I just wanna go back original. Its at the body shop now and I get it back in two weeks- I know one is the white pin stripe but what is the other W code? Its an N96 should I just cut down the hood stripes and install what I have room for
Chris
The fender tag reads as follows
First Tag second tag
N85 N96 R26 V7W V8W C10
M21 M25 M31 N41 N42
C55 C62 G36 J45 J52 L31
VIW U AO1 A36 B11 C16
FE5 V6XW TX9 926 046212 26 END
E86 D32 RS23U16121984 YX RS231U6121984
Re: 1971 GTX Fender tag Question V7W and V8W Help! [Re: lawnmanlex] #971507
04/21/11 07:50 AM
04/21/11 07:50 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
No. No cars came like this from the factory. Leave off that stripe altogether.
As stated previously V7W is the pin stripes. All 71 GTXs had these.
V8W is the hood/fender stripe. Optional on 71 GTXs, not available with N96. Must be a fender tag glitch on your car, as well as some other 71 N96 cars.
V1W is the full vinyl roof. White in this case.
V6XW, should be P6XW, which is white bucket seat interior.
-Jim
Re: 1971 GTX Fender tag Question V7W and V8W Help! [Re: lawnmanlex] #971508
04/21/11 12:41 PM
04/21/11 12:41 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The V8W is some kind of misprint on the tag.
N85 N96 R26 V7W V8W CTD
+ M21 M25 M31 N41 N42 +
VIW -U- AO1 A36 B11 C16
FE5 P6XW TX9 926 046212
E86 D32 RS23 U1G 121984
--- 26 END
--- YX? RS23 U1G 121984
