As seen in this photo from last week's thread on the 440 - it looks like all the blue wires on the new reproduction harness for the 440-4bbl's carb idle solenoid are correct. So that the new harness connects to the alternator and the engine harness connects to the new harness. In this pic the black idle solenoid ground isn't connected to anything yet and neither is the dist solenoid's blue 'batt' wire.
All that is left remaining is 1) connect the black ground lead from dist solenoid to the black lead originating at the idle solenoid harness.
And 2) to connect the blue female bullet connector off the dist solenoid (batt) to the blue male bullet connector exiting out of the main engine harness.
Wired any other way just isn't correct concerning the factory wiring diagram.
That just leaves reference pics for the 1970 440-6's built after Jan. 1, 1970 - I'd guess the wiring diagram also fails to show the bullet connectors. Maybe some of the guys here have had enough yet?!
I don't own a 440 or a 440-6 - want to thank the guys for the reference pics on the 383 and hope the rest that do own the RB's will have some good pics for the future when it comes time to initial fire-up.
