Max CR with BB MP 590 Cam #970845
04/10/11 10:11 PM
04/10/11 10:11 PM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
Anyone got experience with running over 11:1 on pump gas with the MP 590 cam in a big block (aluminum heads)? If so, what's the CR (and did you measure or guess), what's the installed CL of the cam (I think straight up is 104), what max advance did you run on ignition, and what was your cranking compression gauge reading?
Other pertinent details on you combo would also be appreciated.
Race gas blenders / octane boosters / E-85'ers need not apply, I'm looking for guys running straight 91 or 93 AKI pump gas.
Thanks!
Scott
Re: Max CR with BB MP 590 Cam [Re: Scott58] #970846
04/10/11 10:20 PM
04/10/11 10:20 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
that cam is pretty long in Dur.. think in the 265-268 range@.50..
I ran that cam with a 11:1 493 with mildly ported Eddy RPM's and it ran strong... If your running a stock stroke engine IMO the compression needs to be as high as you can achieve... It will only run bettter. Most say 12-12.5:1+ is idea.. Its just hard to get these compression numbers with stock heads without dome pistons, and shaved heads.
Re: Max CR with BB MP 590 Cam [Re: Scott58] #970847
04/10/11 10:46 PM
04/10/11 10:46 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I would think with a 590 and alum heads ... that the MINIMUM CR you would want is 11 to 1 !
Re: Max CR with BB MP 590 Cam [Re: Bob_Coomer] #970848
04/10/11 11:28 PM
04/10/11 11:28 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
that cam is pretty long in Dur.. think in the 265-268 [Email]range@.50..
That camshaft is 271 @050.MP used to tell you it was 265,but they have updated the paperwork finally.
I ran that shaft in a stock stroke 440,9.8 to 1 actual.MP 452 aluminum heads,38 degrees total timing.My cranking compressiion was 165-170.
A good friend of mine runs the same setup,at 11.3 to 1 36 degrees total timing,unknown cranking comp.
Another racer I know runs his at 9.0 to 1 iron headed,38 degrees total.
We all ran(or still run)93 octane pump gas.
Keep in mind,the fuel may be different where you are,most everywhere around here has ethenol in it.
Even the car with the low compression/ iron heads runs real well, he ha one many races and championships in his car.
By the way,I ran mine mine at 104 intake centerline,so did my friend.Not sure on the other guy's build.
Keith
Re: Max CR with BB MP 590 Cam [Re: Dunnuck Racing] #970849
04/11/11 06:51 AM
04/11/11 06:51 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I run the .590 in a 440 with rpm's, 12.5.1 comp, cam in at 104.
I haven't started tuning it yet, i run 34 degrees timing.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Max CR with BB MP 590 Cam [Re: deaks] #970850
04/11/11 10:53 AM
04/11/11 10:53 AM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
With pump gas?
Re: Max CR with BB MP 590 Cam [Re: Scott58] #970851
04/11/11 11:26 AM
04/11/11 11:26 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Friend had that cam in a 446 RPM eddies with 10 to 1 in at 100 and I'm sure he could have ran 87 but he put 94 in it. when we advanced the cam from 104 it picked up a couple tenths and he could leave 1000 rpm less torque at the line.
I ran a 263/271 ultradyne in at 102 for years with 11.75 to 1 SR heads on 94.
Your cranking compression is only going to be 185 ish and I assume a 4500 plus stall. as rpms increase octane requirements decrease.
I would say 93 your fine you may be able to ween it to 91.
This past year I ran 12 to 1 272/282 @ .050 on 94 same heads.
Re: Max CR with BB MP 590 Cam [Re: Dodgem] #970852
04/11/11 12:14 PM
04/11/11 12:14 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
What spring pressures does that cam require? And whats yall's shift points?Sorry for the hyjack
74 dart sport 440 www.Csucarbs.com
Re: Max CR with BB MP 590 Cam [Re: shoebox] #970853
04/11/11 02:08 PM
04/11/11 02:08 PM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
I'm using the Isky 8005A spring for this build, 135# on the seat and about 385# over the nose (1.6 rockers), but its a 520 and we won't be reving all that high. I think a lot of people use the Comp 928, puts about 160 on the seat and about 380 at lift.
My situation is that due to a couple of goofs I'm half a point higher on compression than I originally planned to be (11:1 with a catalog gasket), I've got CR choices of 11.1, 11.3 or 11.6 depending on the head gasket (11.6 is with the same gasket I originally planned on for 11:1!). I'm a little shy about the 11.6 on pump gas, so I'm looking for some confirmation / experience before I finish up the build.
Scott
Re: Max CR with BB MP 590 Cam [Re: shoebox] #970854
04/11/11 03:47 PM
04/11/11 03:47 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
On my cam with 906 the ultradyne 263/271 we used mopar 077 springs and they were about 150 on the seat sifted 6600 to 6800.
Then put on Indy SR's with the springs that come with them good to .650 lift think they were about 160 seat new and after 5 years were 150 ish and would shift it 7000 to 7200
On the 590 in my buddies not sure but they were a mopar spring
before buddy sold it we check and his seat pressure was 120 and it never floated at 7000 shifts but over the top they were almost 600 really multypied up.
used the stock eddie springs a first and they were fine?? good to .600 lift??
Re: Max CR with BB MP 590 Cam [Re: Scott58] #970855
04/11/11 04:42 PM
04/11/11 04:42 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I run a .590 installed at 106-c/l. 1.6 ratio rockers,Stage-6 heads w/63cc. chambers.
I run 93 umleaded ONLY .
My compression comes out with a measured assembled engine at exactly 12.34cr.
#4 cyl. try and does detonate if I try to use a 2-step. But thats a manifold issue.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Max CR with BB MP 590 Cam [Re: 6bblFLASH] #970856
04/11/11 06:30 PM
04/11/11 06:30 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
Id love to use that cam with mysprings 130/330 pressures but idunno ifwould work
Re: Max CR with BB MP 590 Cam [Re: shoebox] #970857
04/11/11 07:07 PM
04/11/11 07:07 PM
Mooresburg, Tn
'72CudaRacer Online content
'72CudaRacer  Online Content
Mooresburg, Tn
I run that cam straight up (104*) with 13.6:1 compression. I have Ross domed pistons, Stealth heads, Team G intake, 1050 Dominator (8896), MP roller tipped alum rockers w/ 1.5 ratio, and Sunoco 112 racing fuel. This combo is almost 600 hp and I did break a main cap after 300 passes. I put a main stud girdle on last week and ran this weekend, 10.49 in 1/4 and 6.56 in 1/8. When I advanced this cam 2*, it had way too much torque. I am running 35* timing
If you need any more info about mine, just ask, I'll help as much as I can.
Brian Dunnigan
Re: Max CR with BB MP 590 Cam [Re: '72CudaRacer] #970858
04/11/11 09:00 PM
04/11/11 09:00 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I ran the 590 cam in my old car with Isky 8005a springs, cam in at 104, compression was 11.2:1, car was 3050# with me in it. It went 9.90's in the 1/4 at 136 MPH. Great street strip cam! I had 451 cubes and Eddy heads, M1 TR with 2 750's. Current owner has gone 9.77 thru the muffs!
Re: Max CR with BB MP 590 Cam [Re: ProSport] #970859
04/11/11 11:09 PM
04/11/11 11:09 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
What was shift point?
Re: Max CR with BB MP 590 Cam [Re: shoebox] #970860
04/12/11 09:38 PM
04/12/11 09:38 PM
Mooresburg, Tn
Mooresburg, Tn
I shift at 6200. 1/4 mile trap rpm is 6800-6900.
Brian
Re: Max CR with BB MP 590 Cam [Re: '72CudaRacer] #970861
04/12/11 09:50 PM
04/12/11 09:50 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
493, 10.5cr, 185 cranking comp, 93 pump gas, installed at 105. rpm heads, six pack, ran 10.50s at 3700lbs, shifted at 5800, used the isky's 8005a also
Re: Max CR with BB MP 590 Cam [Re: ProSport] #970862
04/13/11 01:25 AM
04/13/11 01:25 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That was a great running combo. Ron
