Re: Tach diagram fro '70 Bee...
[Re: 71_deputy]
#970624
04/10/11 08:44 PM
04/10/11 08:44 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
yes it is the factory tach,just like in the Charger, but without the clock, but someone messed with the wiring under the dash before me, now I have to reconnect it.......
Dan
[Re: Wedgeman]
#970630
04/10/11 09:17 PM
04/10/11 09:17 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I have one for sale with the clock, and needs a dash pad but, it's a 68 so it has the key switch. That tach looks different than the other gauges in the dash. Cleaner and the numbers are much smaller, that came from the factory? It'll look good with a little cleaning.
[Re: Wedgeman]
#970635
04/11/11 02:00 PM
04/11/11 02:00 PM
Posts: 8,827 Houston, Tx
hemi68charger
Houston, Tx
You're sure ?......not questionning your knoeledge there.........
Not a factory tach.. Does the fender tag, if in possession, have N85 on it? If not, then it probably came with either a clock or a delete plate. All the tachs in the "rallye" instrument cluster had a clock. Now, there was a hood-mounted tach... Not too many of those around for good reason... Yuck...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#970636
04/11/11 02:06 PM
04/11/11 02:06 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Oh yeah; I forgot about the hood mounted one....
All the clusters I've seen have either;
- the delete plate: just a black plate with a white cross on it IIRC
- the clock (most common from what I've seen)
- the tic toc tach
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: 469runner]
#970637
04/11/11 07:46 PM
04/11/11 07:46 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
That is not a factory tach. Looks like a neat job installing an aftermarket by someone.
i friggin knew it!!
