Tach diagram fro '70 Bee... #970620
04/10/11 06:42 PM
04/10/11 06:42 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Hi guys
I need a wiring diagram for the tach only (no clock) in my '70 Super bee 6 wires total are coming out..
thanks
Dan
Re: Tach diagram fro '70 Bee... [Re: Wedgeman] #970621
04/10/11 07:28 PM
04/10/11 07:28 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Re: Tach diagram fro '70 Bee... [Re: mikemee1331] #970622
04/10/11 07:39 PM
04/10/11 07:39 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Went there.......they don't have it in their diagramms
Re: Tach diagram fro '70 Bee... [Re: Wedgeman] #970623
04/10/11 08:23 PM
04/10/11 08:23 PM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
is this a factory tach????
add on???
have a pic?
Re: Tach diagram fro '70 Bee... [Re: 71_deputy] #970624
04/10/11 08:44 PM
04/10/11 08:44 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
yes it is the factory tach,just like in the Charger, but without the clock, but someone messed with the wiring under the dash before me, now I have to reconnect it.......
Dan
Re: Tach diagram fro '70 Bee... [Re: Wedgeman] #970625
04/10/11 08:53 PM
04/10/11 08:53 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
6 wires? arre you sure they are all for the tach?
Re: Tach diagram fro '70 Bee... [Re: mikemee1331] #970626
04/10/11 09:09 PM
04/10/11 09:09 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Live and learn.
I never knew they made a tach that was not a tic toc tac for 68 to 70 b-bodies. Except for the little one that were used on plymouths (standard dash not ralley)in place of the clock.
Re: Tach diagram fro '70 Bee... [Re: bboogieart] #970627
04/10/11 09:11 PM
04/10/11 09:11 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Here is a pic
Re: Tach diagram fro '70 Bee... [Re: Wedgeman] #970628
04/10/11 09:14 PM
04/10/11 09:14 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Neat!!!!!!!!!!!!
That's factory? I like it. Are they hard to find?
Re: Tach diagram fro '70 Bee... [Re: Wedgeman] #970629
04/10/11 09:14 PM
04/10/11 09:14 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I know......this is one ugly dash !! loll
Re: Tach diagram fro '70 Bee... [Re: Wedgeman] #970630
04/10/11 09:17 PM
04/10/11 09:17 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I have one for sale with the clock, and needs a dash pad but,
it's a 68 so it has the key switch.
That tach looks different than the other gauges in the dash.
Cleaner and the numbers are much smaller, that came from the factory?
It'll look good with a little cleaning.
Re: Tach diagram fro '70 Bee... [Re: bboogieart] #970631
04/11/11 12:05 AM
04/11/11 12:05 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
That is not a factory tach. Looks like a neat job installing an aftermarket by someone.
Re: Tach diagram fro '70 Bee... [Re: 469runner] #970632
04/11/11 12:45 AM
04/11/11 12:45 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
You're sure ?......not questionning your knoeledge there.........
Re: Tach diagram fro '70 Bee... [Re: Wedgeman] #970633
04/11/11 09:32 AM
04/11/11 09:32 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
not factory- just a nice fit as stated
factory tachs usually on have 3 connections
switched + 12 volts
ground
- pulses from coil
dash pod provides nighttime light.
now after market types ususally have 4 wires for all four above- but six????
there will be a manufactures name somewhere on it- find and google it- you might find what the other two wires.
Re: Tach diagram fro '70 Bee... [Re: Wedgeman] #970634
04/11/11 01:47 PM
04/11/11 01:47 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I don't pretend to know everything about '70 'Bees but I have spent the last 5 years researching them and I currently have 4 '70 rallye clusters on the shelf and probably looked at all for sale on e-bay for several years.......never seen a tach like that. I'd give it a 99% chance of being aftermarket.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Tach diagram fro '70 Bee... [Re: Wedgeman] #970635
04/11/11 02:00 PM
04/11/11 02:00 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Not a factory tach.. Does the fender tag, if in possession, have N85 on it? If not, then it probably came with either a clock or a delete plate. All the tachs in the "rallye" instrument cluster had a clock. Now, there was a hood-mounted tach... Not too many of those around for good reason... Yuck...
Troy
Houston Mopar Connection Club
Re: Tach diagram fro '70 Bee... [Re: hemi68charger] #970636
04/11/11 02:06 PM
04/11/11 02:06 PM
DPelletier Offline
DPelletier  Offline
Oh yeah; I forgot about the hood mounted one....
All the clusters I've seen have either;
- the delete plate: just a black plate with a white cross on it IIRC
- the clock (most common from what I've seen)
- the tic toc tach
Re: Tach diagram fro '70 Bee... [Re: 469runner] #970637
04/11/11 07:46 PM
04/11/11 07:46 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i friggin knew it!!
Re: Tach diagram fro '70 Bee... [Re: mikemee1331] #970638
04/11/11 09:17 PM
04/11/11 09:17 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Then it's out !!
Thanks..
Dan
