Grease gun malfunction - tip stuck on car. What the..?? #970611
04/10/11 06:23 PM
04/10/11 06:23 PM
Albany, NY
67SATisfaction Offline OP
The member whose name is actually Art
Albany, NY
Guys,
My trusty ol' grease gun just did something very weird. Has anyone had the tip stuck on the car?.....
FIRST: I attached the tip to a standard greasenipple, extended the pump handle and the handle LOCKED in the "open" position. Not budging. No "give" in it either, no softness or squishy feel. Like it's mechanically overextended?
THEN: I went to remove the tip and it's totally STUCK on the greasenipple. Can't get it off. Tried prying it off between needlenosed pliers wedged under the tip. No dice.
I pressed the pressure relief button and the little ballvalve on the cartridge fitting. Nothing. I removed the cartridge, there's plenty of grease left.
The handle remains extended and the tip remains stuck.
Any ideas?
Thanks, -Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Grease gun malfunction - tip stuck on car. What the..?? [Re: 67SATisfaction] #970612
04/10/11 06:30 PM
04/10/11 06:30 PM
Kirkland, Washington
Pacnorthcuda Offline
Is there enough room to get a wrench on the zerk?
Re: Grease gun malfunction - tip stuck on car. What the..?? [Re: 67SATisfaction] #970613
04/10/11 06:33 PM
04/10/11 06:33 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Give it a wack with a hammer or pry it up with a screwdriver.
Re: Grease gun malfunction - tip stuck on car. What the..?? [Re: NITROUSN] #970614
04/10/11 07:29 PM
04/10/11 07:29 PM
IN
ahy Offline
ahy  Offline
IN
Sounds like the grease nipple is plugges solid and pressure is holding the gun tip on and locking the handle. I'd unscrew the small tube from the gun to nipple - that may relieve it then try to unscrew the zerk as suggested above.
Re: Grease gun malfunction - tip stuck on car. What the..?? [Re: 67SATisfaction] #970615
04/10/11 07:30 PM
04/10/11 07:30 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Usually the tip is threaded and has a knurled grip on it. By turning the tip, you can loosen or tighten the fit on the zirk fitting. Sometimes the tip can turn unintentionally tighter or looser.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Grease gun malfunction - tip stuck on car. What the..?? [Re: GO_Fish] #970616
04/10/11 08:16 PM
04/10/11 08:16 PM
Albany, NY
Albany, NY
Thanks for the ideas guys, I'll see what works and let ya know!
-Art
