mis-aligned clutch plates: 8 3/4 #969742
04/09/11 08:19 AM
04/09/11 08:19 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
checking out an 8 3/4 axle with a limited-slip and after pulling the axles i couldn't re-install the drivers side all the way. after closer inspection i found the inner set of clutch plates moved to where they are not aligned with the outer set. i tried to move them with no luck. any ideas on getting them back in alignment? thanks, dave
Re: mis-aligned clutch plates: 8 3/4 [Re: 3ddart] #969743
04/09/11 10:43 AM
04/09/11 10:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
sounds like a clutch type and it's not the clutch plate as they are splined to the OD of the side gears . Unfortunately the original clutch type has 2 piece side gears and what you had happen does happen .
Hopefully Doc Diff will chime in , but he may be at the MATS ???
Re: mis-aligned clutch plates: 8 3/4 [Re: 3ddart] #969744
04/09/11 10:54 AM
04/09/11 10:54 AM
Under My Car
Mopar_Country Offline
Under My Car
Loosen the bolts on the sure grip slightly to relieve the pressure on the side gears and put an axle in there to line them up. Leave the axle in and tighten the bolts back up.
If you ever get into rebuilding these a lot it's handy to have axle shaft ends cut off from bad axles as an alignment tool.
Re: mis-aligned clutch plates: 8 3/4 [Re: JohnRR] #969745
04/09/11 10:59 AM
04/09/11 10:59 AM
MINNESOTA
BRONZEBEE Offline
BRONZEBEE  Offline
MINNESOTA
I had a cone style do that to me after a rebuild.Install the other axle and hold it still,or put on ground with the tire.Slide in the other axle until it stops then turn with a large pry bar on the wheel studs and push while turning.
Re: mis-aligned clutch plates: 8 3/4 [Re: BRONZEBEE] #969746
04/09/11 11:07 AM
04/09/11 11:07 AM
Under My Car
Under My Car
If you have not removed the chunk, then try this method.
EDIT: Also look down the tube and make sure the thrust buttons are still in place. There is one on each side in the suregrip, these allow for axle end play adjustment.
Re: mis-aligned clutch plates: 8 3/4 [Re: BRONZEBEE] #969747
04/09/11 11:29 AM
04/09/11 11:29 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I had a cone style do that to me after a rebuild.Install the other axle and hold it still,or put on ground with the tire.Slide in the other axle until it stops then turn with a large pry bar on the wheel studs and push while turning. [/quote
Do this.. I've do it quite a few times, it works...
Re: mis-aligned clutch plates: 8 3/4 [Re: 1_WILD_RT] #969748
04/09/11 11:52 AM
04/09/11 11:52 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
thanks guys!! i knew moparts would come through. i also thought it might be a thrust button that fell off of the pin but i had looked and they were in place. i've removed the pig so i may try mounting it on a engine stand to try the wiggle and push method and if that won't work i'll loosen the bolts and try. thanks again! dave
Re: mis-aligned clutch plates: 8 3/4 [Re: 3ddart] #969749
04/09/11 12:02 PM
04/09/11 12:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Loosening the bolts won't help unless you take the carrier out of the case, the side bearings will hold the two halves together... If you decide to take it apart measure the backlash first mark the adjusters & the caps... Count the turns .. The thing is if the clutches are good you'll have a hard time getting enough torque on the axles with the unit not solidly mounted in the car... As mentioned, one tire on the ground then either a bar or I've used the other wheel to get leverage to turn the axle forcing the clutches to slip.. While turning push inward.... It make take turning forward and rearward but it will go...
Re: mis-aligned clutch plates: 8 3/4 [Re: 1_WILD_RT] #969750
04/09/11 12:12 PM
04/09/11 12:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I agree , put it back in the car .
Re: mis-aligned clutch plates: 8 3/4 [Re: JohnRR] #969751
04/09/11 12:26 PM
04/09/11 12:26 PM
Under My Car
Under My Car
Forgot to mention that. Try the aforementioned pry bar and turning method before removing the pig, they should go.
Re: mis-aligned clutch plates: 8 3/4 [Re: Mopar_Country] #969752
04/10/11 06:36 PM
04/10/11 06:36 PM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
again, thanks guys!! i did reinstall the center section and drive shaft and put the right side axle in. then took a b-body axle (because of the extra lenght it gave better finger clearence), i held the right side brake drum and my friend used a big cresent and did the wiggle and push deal. it's back together and i took it down the road this afternoon. thanks again to all! dave
Re: mis-aligned clutch plates: 8 3/4 [Re: 3ddart] #969753
04/10/11 11:34 PM
04/10/11 11:34 PM
MINNESOTA
BRONZEBEE Offline
BRONZEBEE  Offline
MINNESOTA
Good to hear.Does it work?
Re: mis-aligned clutch plates: 8 3/4 [Re: BRONZEBEE] #969754
04/11/11 08:52 AM
04/11/11 08:52 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
yea, it's fine. i was chasing a shimmy as you would slow to a stop. seems 1 of my centerlines is slightly bent. dave
