67 Dart strut rod question #969729
04/09/11 05:32 AM
04/09/11 05:32 AM
SW Missouri
moparmandjh Offline OP
SW Missouri
My nephew is rebuilding the front suspension on his 67 Dart. One of his strut rods is bent approximately 1/8-1/4 inch. You can barely see it until you roll it on a flat surface. How critical is it that they are perfectly straight?
Doc
American soldiers in battle don't fight for what some president says on tv, they don't fight for mom, apple pie, or the American flag... they fight for one another. -Lt. General Hal Moore
Re: 67 Dart strut rod question [Re: moparmandjh] #969730
04/09/11 09:13 AM
04/09/11 09:13 AM
bend it back straight WO putting any nicks into it
Re: 67 Dart strut rod question [Re: RapidRobert] #969731
04/09/11 09:18 AM
04/09/11 09:18 AM
SW Missouri
SW Missouri
That sounds fun.
Doc
Re: 67 Dart strut rod question [Re: moparmandjh] #969732
04/09/11 09:59 AM
04/09/11 09:59 AM
Doc, make him do it (you supervise)
Re: 67 Dart strut rod question [Re: RapidRobert] #969733
04/09/11 10:14 AM
04/09/11 10:14 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Heat it and strighten it.We did one on my kids Express truck which is a lot heavier than a Darts.Dont worry about nicking it.Its not a Tbar.They basically just keep the lowerA arm in place.If bent real bad it could move caster a bit.They also make adjustables as well as solid ones aftermarket.Rocky
Chrysler Firepower
Re: 67 Dart strut rod question [Re: therocks] #969734
04/09/11 10:29 AM
04/09/11 10:29 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: 67 Dart strut rod question [Re: JohnRR] #969735
04/09/11 11:31 AM
04/09/11 11:31 AM
Montana
Y
Yancy Derringer Offline
Y
Montana
If you have to roll it on a flat to be able to see it, I say LEAVE IT alone.
Re: 67 Dart strut rod question [Re: therocks] #969736
04/10/11 09:04 AM
04/10/11 09:04 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Heat on a suspension piece? No way.
Find someone with a press or play it safe and replace it.
Re: 67 Dart strut rod question [Re: gdonovan] #969737
04/10/11 09:13 AM
04/10/11 09:13 AM
IN
ahy Offline
ahy  Offline
IN
Quite a few of the strut rods were manufactured with a slight "dog leg" at the ends. The dogleg doesn't seem to hurt anything. Is this causing the wobble or is the "straight part" of the shaft bent?
Re: 67 Dart strut rod question [Re: ahy] #969738
04/10/11 03:04 PM
04/10/11 03:04 PM
SW Missouri
SW Missouri
It has a slight dog leg at one end. I think someone put a jack under it and lifted the nose. Thanks for all the help guys!!!!
Doc
