The New J/E pistons are finally here!! :) #969521
04/08/11 07:38 PM
04/08/11 07:38 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
Took a solid 4 weeks but here they are!!!
Re: The New J/E pistons are finally here!! :) [Re: Diablo] #969522
04/08/11 07:38 PM
04/08/11 07:38 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
pic 2
Re: The New J/E pistons are finally here!! :) [Re: Diablo] #969523
04/08/11 08:27 PM
04/08/11 08:27 PM
@ the shop
E
E-85 408 DART Offline
E
@ the shop
very nice !!!
"Tappet" lead fabricator for the legendary "Flat & Tappet" race team .
Re: The New J/E pistons are finally here!! :) [Re: E-85 408 DART] #969524
04/08/11 08:54 PM
04/08/11 08:54 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
very nice, now lets hear how much. what was the weigh in on those bad boys and what wall pins did you chooose?
Re: The New J/E pistons are finally here!! :) [Re: Deepockets] #969525
04/08/11 09:18 PM
04/08/11 09:18 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
Pistons, pins, and rings ended up just under 1400$
Pistons are for a 4.570 bore.
Pistons weighed in at 611 grams. Although these pistons don't have oil ring buttons but a special ring that does the same job which saved 32 grams that other pistons would have added on to them. The special ring they give now only weighs 8 grams.
We went with 180 wall pins weighing in at 171grams.
This is a truck pulling engine so it see's 8000rpm for 80% of the run and Gary at J/E didn't want to go any lighter on the pins.
Re: The New J/E pistons are finally here!! :) [Re: Diablo] #969526
04/08/11 09:31 PM
04/08/11 09:31 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Now get that thing together DJ. I can smell a points championship this season. The Rock doesn't stand a chance.
Re: The New J/E pistons are finally here!! :) [Re: mac56] #969527
04/09/11 09:07 AM
04/09/11 09:07 AM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
Thanks Mark!
Picking up the block and balanced crank this morning! Heads will be done next week! Need to order some little things but all the big stuff should be done now! Cross our fingers!!!
Re: The New J/E pistons are finally here!! :) [Re: Diablo] #969528
04/09/11 10:13 AM
04/09/11 10:13 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
1400 beans ... sounds like someone has a really deep-wallet !
Re: The New J/E pistons are finally here!! :) [Re: dOoC] #969529
04/10/11 01:47 PM
04/10/11 01:47 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
Sadly that's just what they cost:(. Called a few places and for what I needed they were pretty much the cheapest for the quality:)
Re: The New J/E pistons are finally here!! :) [Re: Diablo] #969530
04/10/11 02:45 PM
04/10/11 02:45 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
My Custom Diamond piston/ pin/ ring package was about the same...
I used .185" wall tool steel pins as well.
Diablo, I think you chose well. The weight of the pistons is not as important as the strength in a combo like yours!
Good luck with the build.
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: The New J/E pistons are finally here!! :) [Re: Diablo] #969531
04/10/11 02:55 PM
04/10/11 02:55 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
D ... never had a set of pistons done like this myself .. but I thought that a typical set was 8 huN or so. I see that your ring-pack is way low .... also see those deep gas-ports.
They are some nice looking pieces ...
