Page 3 of 3 1 2 3
Re: stuck dampener [Re: JohnRR] #969101
04/08/11 05:32 PM
04/08/11 05:32 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
To the guys that have had to honed-to-fit these things ....what have you used to do-so ?
A small engine hone...
I had it done at the machine shop , he measured it and did it in the rod hone .
I try to do everything myself, bad habit I have.
Re: stuck dampener [Re: Challenger 1] #969102
04/08/11 05:51 PM
04/08/11 05:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It seemed like a precision operation to me so I thought I'd leave it to a trained professional , plus he only charged me 20 bucks. I'M like you though and I try to do as mauch as possible myself , which is why I rarely finish anything I think.
Re: stuck dampener [Re: JohnRR] #969103
04/08/11 06:04 PM
04/08/11 06:04 PM
Cincinnati, Ohio
Cincinnati, Ohio
It is a precision job, for sure. I have a dial bore gauge and a set of mics, No different than fitting bearings.
yup finishing stuff is the toughest unless you got a guy waiting to drive it, story of my life.
Re: stuck dampener [Re: JohnRR] #969104
04/08/11 07:34 PM
04/08/11 07:34 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
X2. ATI recommends .008"-.0011 interference fit. I mic'd the crank and dropped the balancer off at the shop. As it turned out the balancer was within spec as delivered.
These are the instructions that came with a buddy's CCJ balancer:
Re: stuck dampener [Re: 64Post] #969105
04/08/11 08:25 PM
04/08/11 08:25 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Re: stuck dampener [Re: Roger 68 Charger] #969106
04/08/11 09:03 PM
04/08/11 09:03 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I just finished putting my dampener on (PRW) Man what a pain--I heated it up in water and used anti seize--but it went on hard all the way. The instructions didnt say anything about honeing and I didnt think of it
Man that thing is going to be a pain in the ass to get off
Consider that a gift. Mine hit the timing tab before it even touched the crank when I tried to fit it...before I found it didnt fit the crank.
Onto the "shelf of stOOpidity" it went!
Re: stuck dampener [Re: POS Dakota] #969107
04/08/11 11:44 PM
04/08/11 11:44 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
BEST to have to "fit" the dampner .. than have it tooo loose. I checked the new one I had ... and it might even have-to-be BORED-to-fit !! ...
Re: stuck dampener [Re: 64Post] #969108
04/09/11 10:18 AM
04/09/11 10:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
question on the spec, .008 OR .0008 ??? .008 you would need to use a 100 ton PRESS to get that on ...
Re: stuck dampener [Re: JohnRR] #969109
04/11/11 09:43 AM
04/11/11 09:43 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Yep he needs another 0 in there for sure.
Page 3 of 3 1 2 3
