Is it safe 2.19/1.88 on 452 iron heads ? #968695
04/07/11 06:45 PM
04/07/11 06:45 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
what you read.
Re: Is it safe 2.19/1.88 on 452 iron heads ? [Re: NachoRT74] #968696
04/07/11 11:33 PM
04/07/11 11:33 PM
No actual exp. Just from the math it'd move the in/ex valve inside edges .125" closer (starting w 2.08/1.74). If that would work w no interference you could plunge cut the walls to unshroud the rest
Re: Is it safe 2.19/1.88 on 452 iron heads ? [Re: NachoRT74] #968697
04/07/11 11:47 PM
04/07/11 11:47 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You don't want 1.88 exhaust valves anyways 1.81 is about as big as you would want to go.
2.19/1.88 may actually hit.
Re: Is it safe 2.19/1.88 on 452 iron heads ? [Re: Dodgem] #968698
04/08/11 12:00 AM
04/08/11 12:00 AM
2.14/1.81 is the std oversize combo. Just wondering would 2.19/1.81 or 2.14/1.88 be better or worse
Re: Is it safe 2.19/1.88 on 452 iron heads ? [Re: RapidRobert] #968699
04/08/11 12:31 AM
04/08/11 12:31 AM
Valencia, España
Valencia, España
yes thats why I'm asking... I allways have known about 2.14/1.81 oversizes, but really suprised me when I saw the 2.19/1.88 option too even from MP
actually MP offers 2.20 not 2.19
I have though about a 2.14/1.88 combination too.
Not now, but in a future ( unless I screwed up porting my heads now LOL )
Re: Is it safe 2.19/1.88 on 452 iron heads ? [Re: NachoRT74] #968700
04/08/11 12:56 AM
04/08/11 12:56 AM
Long Island, NY.
Stroked65Belv Offline
Long Island, NY.
I have the exact set up on my 452 cast heads. Were done by Indy years ago. Still in use and flow well on my 498 stroker. Was an expensive set up years ago but you can do better now out of the box with stock alum heads at more reasonable $$$ these days..
Re: Is it safe 2.19/1.88 on 452 iron heads ? [Re: Dodgem] #968701
04/08/11 01:04 AM
04/08/11 01:04 AM
Valencia, España
Valencia, España
why?
