383 to 440 swap in 1970 Road Runner #968636
04/07/11 05:31 PM
04/07/11 05:31 PM
New Jersey, USA
JeffRacerG Offline OP
New Jersey, USA
I have the opportunity to swap a nice 1971 440 into my Road Runner where a 383 now sits. Plan is to eventually rebuild the 383. Anything I should know about the swap. Can I use the same bell housing, motor mounts, exhaust manifolds, etc? The 440 has the crank drilled for the pilot bushing.
From what I remember it can be a direct swap, just wanted to be sure.
Thanks for the anticipated information.
Re: 383 to 440 swap in 1970 Road Runner [Re: JeffRacerG] #968637
04/07/11 05:45 PM
04/07/11 05:45 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
in one word, yes
Re: 383 to 440 swap in 1970 Road Runner [Re: JeffRacerG] #968638
04/07/11 05:49 PM
04/07/11 05:49 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
should be a 1 to 1 swap! that's a sweet ride you have there. where in Jersey are you?
Re: 383 to 440 swap in 1970 Road Runner [Re: JeffRacerG] #968639
04/07/11 05:51 PM
04/07/11 05:51 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I guess 440 has the intake and the dist too. If not, will need the right ones on this miscelaneous
Re: 383 to 440 swap in 1970 Road Runner [Re: NachoRT74] #968640
04/07/11 05:58 PM
04/07/11 05:58 PM
New Jersey, USA
New Jersey, USA
Yep. Intake and the distributor are on the 440. You are saying the exhaust manifolds from the 383 will work and bolt to my exhaust system?
Thanks for the quick confirmation of what I thought. I'm located in Brick, N.J., near the beach at Point Pleasant.
Re: 383 to 440 swap in 1970 Road Runner [Re: JeffRacerG] #968641
04/07/11 06:02 PM
04/07/11 06:02 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
direct swap and you'll NEVER go back to that 383
Coming soon!!!!
Re: 383 to 440 swap in 1970 Road Runner [Re: JeffRacerG] #968642
04/07/11 06:03 PM
04/07/11 06:03 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
should be a direct bolt up. same heads. and nope, i'm not coming to see your car. can't deal with all that traffic !
Re: 383 to 440 swap in 1970 Road Runner [Re: JeffRacerG] #968643
04/07/11 06:09 PM
04/07/11 06:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Only potential will be the exhaust system if you have an H or X pipe , the 440 is wider and the manifolds are about 3/4" higher up .
Re: 383 to 440 swap in 1970 Road Runner [Re: JeffRacerG] #968644
04/07/11 06:41 PM
04/07/11 06:41 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Dunno if you are planing on use the 440 exhaust manifolds but juts in case I would keep the 383 exhaust manifolds you actually have... the diff on years could make diff flange exhaust bolt holes indexing making don't match with your pipes flanges.
