Re: 383 to 440 swap in 1970 Road Runner
[Re: JeffRacerG]
#968639
04/07/11 05:51 PM
04/07/11 05:51 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I guess 440 has the intake and the dist too. If not, will need the right ones on this miscelaneous
[Re: JeffRacerG]
#968643
04/07/11 06:09 PM
04/07/11 06:09 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
Yep. Intake and the distributor are on the 440. You are saying the exhaust manifolds from the 383 will work and bolt to my exhaust system?
Thanks for the quick confirmation of what I thought. I'm located in Brick, N.J., near the beach at Point Pleasant.
Only potential will be the exhaust system if you have an H or X pipe , the 440 is wider and the manifolds are about 3/4" higher up .
