Page 1 of 5 1 2 3 4 5
What did I do wrong on my ministarter - NOTHING! Fixed. #968540
04/07/11 04:42 PM
04/07/11 04:42 PM
South-Central (Sebring), FL
Commando1 Offline OP
Installed a new mini starter from Mancini onto my 440.
I ground away the necessary material to make it fit.
Hit the ignition and the starter spins but the Bendix drive is not engaging the starter ring.
What am I not doing correctly? Out of a gazillion starters this is my first mini. Thanks.
And while we're on the subject, anybody have a pic of where they had to grind away material?
Re: What did I do wrong on my ministarter [Re: Commando1] #968541
04/07/11 04:44 PM
04/07/11 04:44 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Tap it? Maybe the bendix is stuck...Who knows how long it has been sitting on a shelf
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: What did I do wrong on my ministarter [Re: Pyper70] #968542
04/07/11 04:45 PM
04/07/11 04:45 PM
First thing I did was to persuade it with my BFH.
Re: What did I do wrong on my ministarter [Re: Commando1] #968543
04/07/11 05:20 PM
04/07/11 05:20 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
That's why I use the stock boat anchor starters on everything.....plus they sound better than those new ones
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: What did I do wrong on my ministarter [Re: Commando1] #968544
04/07/11 05:30 PM
04/07/11 05:30 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
No, you installed a 'returned for defect' starter that sat on the shelf from Mancini...
Re: What did I do wrong on my ministarter [Re: 64Post] #968545
04/07/11 05:38 PM
04/07/11 05:38 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I never had to grind away material, I just remove the pos cable lug extender (or whatever it's called), there's another lug to attach to underneath.
Re: What did I do wrong on my ministarter [Re: 64Post] #968546
04/07/11 06:18 PM
04/07/11 06:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
And now that he ground on it he owns it ... $$$$
Re: What did I do wrong on my ministarter [Re: JohnRR] #968547
04/07/11 06:38 PM
04/07/11 06:38 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I have seen some of them where the starter gets dropped and the snout hits the concrete, and jams it out of line, and the bendix just binds, and cant come out. If thats the case, I sometimes could un jam it, but usually the case it distorted. Are you sure its grounded properly? My demon had fresh paint all over, and the starter wouldnt spin because lack of ground. I cleaned the paint off the bell housing, and even ran its own ground strap, and it workes flawlessly.
Kasey
Re: What did I do wrong on my ministarter [Re: Commando1] #968548
04/07/11 06:52 PM
04/07/11 06:52 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Fromn what I have heard and read, there are different sizes of these guys that fit certain motors. I know that sounds wrong, but somewhere I read that "THIS IS THE ONE THAT FITS B/RB" yadda yadda. There are different ratings on them too, some have longer windings for more torque. Bummer, does the bendix drive shoot out? Certain its in the counterbore of the trans? Yikes!
Re: What did I do wrong on my ministarter [Re: JohnRR] #968549
04/07/11 07:27 PM
04/07/11 07:27 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I learned to always bench test a starter before installing. Doesn't help if there is a fitment issue, though.
Re: What did I do wrong on my ministarter [Re: B5 Bee] #968550
04/07/11 07:30 PM
04/07/11 07:30 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I had to grind mine down from 440 Source. The extension that came on it had to be removed and part of the base had to be shaved down. I covered the mess in electrical tape and heat sink because I went down too deep. Mine never missed a beat from the get go....I was probably a lucky one
Re: What did I do wrong on my ministarter [Re: Commando1] #968551
04/07/11 07:37 PM
04/07/11 07:37 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That sucks, try loosing the bolts just a little and see if it works. Maybe gently tap on it when it's a little loose. Hopefully it'll free up.
The last couple starters I have bought were from the parts store for like a 90 dakota and I don't remember grinding on the starter. Got got rid of the big connector/90 degree thing on the electric connections. Otherwise they fit and have worked great for years now, one of them are at least 10 years old. Never got that kinda of service out of original starters, not me anyway.
Re: What did I do wrong on my ministarter [Re: Pyper70] #968552
04/07/11 07:43 PM
04/07/11 07:43 PM
Central TX
roe Offline
roe  Offline
Central TX
On mine I removed the black "adapter" where the wires connect. As stated, there is a second place under that adapter where the factory wires can also connect to.
I ground on the tip of the nose cone. And I also ground on the case where it faces the flexplate once mounted. I was using an aftermarket flexplate that allowed me to use an unweighted 318 torque converter with a 360. That part of the case was touching the flexplate and would not let the starter mount correctly. When I hit the key, you heard a lot of spinning but the bendix drive could not extend because of the mis alignment. My grinding took care of that. maybe something to look at on yours. I didnt see exactly what was happening with mine until I had someone crank the car while I was under it watching the starter.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: What did I do wrong on my ministarter [Re: Commando1] #968553
04/07/11 07:47 PM
04/07/11 07:47 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
I don't know why Mancini and others say one mini-starter is for a big block, the other small block, maybe they think people are that stupid? I am a small block person myself, and I just went and got one at O'Reillys..before I put it in, My buddy told me he ordered the "Big Block" one from Mancini and asked if i could help install it(He's not so much mechanically inclined)
I go over there and thought I'd take mine along for comparison, I knew you had to grind away a SB starter to fit and I wanted to see what was different.
The body was the exact same on the Mancini "Big Block" and my O'Reilly factory unit. I ground away at different spots where it snugs against that boss on the block as carefully as I could for about 2 hours. Each little bit I buzzed it and check fit, buzz, check fit.. I didn't want to get carried away. I made sure that i had a slight bit of play in the unattached starter before i bolted it in. So I wouldn't bind it.
If you guys who have your BB motors out want to use one of these things, My suggestion is take a little off the block in that looked nook. Some have more there than others. It'd just be better than grinding on starters that you may not be able to get a core exchange on.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: What did I do wrong on my ministarter [Re: Challenger 1] #968554
04/07/11 07:47 PM
04/07/11 07:47 PM
Central TX
roe Offline
roe  Offline
Central TX
Yeah, I got mine from autozone for like $118 with a lifetime warranty. I asked for one for a '90 Dakota with a V6. If I had a stock flexplate I dont think I would have needed to grind anything either. Because once I got it in, I realized the nose cone never needed grinding in the first place, just the case where it was hitting my flexplate that was much bigger than a stock one
Re: What did I do wrong on my ministarter [Re: B5 Bee] #968555
04/07/11 09:18 PM
04/07/11 09:18 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
That's all I had to do on mine also, mounted to a 360 with a B&M flex plate, no grinding anywhere. Pulled my mini out of a 90's full size van that was already up on blocks at the pick & pull.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: What did I do wrong on my ministarter [Re: Commando1] #968556
04/07/11 09:20 PM
04/07/11 09:20 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Do you have a 130 tooth flywheel in a 143 tooth bell???
The way a Denso style starter operates is when the coil surrounding the plunger is energized it pulls the contact ring to the contacts while pushing the drive forward.So if the motor is spinning then the drive is extended.In the hundreds of Denso starters I have worked on in the 28 years of import car world I have yet to see a starter engage and run without the drive extending to contact the ring gear
Gus
Re: What did I do wrong on my ministarter [Re: fourgearsavoy] #968557
04/07/11 09:35 PM
04/07/11 09:35 PM
scratchnfotraction Offline
14$ from the u-pull it
came on a 96 v-6 fit right on the 440,removed the bolt on lug,went right to studs out of starter
used a 93 5.2 mini on the 318 in my 85 truck
I have done at least 25 swaps to SB&BB never had to grind on any of them to fit
all for 14$ used at the u-pull,had one start clicking and would not spin it over...65$ rebuild and 3 yrs later still spiining the 318 over
that stud looks closer than it is in the pic,it has clearance in the cup of the core plug
one place on the block by the small bolts in the stater is the only place I could see that might need a little grinding,but every one I have done had clearance
the mini alt even went on my 440 in the sig pic with stock non a/c brackets and 2 stock power steering pump belts
Re: What did I do wrong on my ministarter [Re: Commando1] #968558
04/08/11 12:59 AM
04/08/11 12:59 AM
This is not sounding too good to me, especially the part about yours not needing any grinding to fit. Yah, I'm p.o.'d now that 'own' the starter. Had to hog out part of the block which left me feeling queasy and then some shaving on the starter itself. All this bs started because my $40 Autozone rebuilt wouldn't crank when hot. So in went a late 90's truck starter from a yard. To make that fit is when all the hogging started. It wouldn't engage so it got returned thinking it was a bum unit. Rather than deal w/another junkyard unit, Iwent to AZ and got the best starter they had. Turned over slower than my cheapo AZ starter so back that went and Idecided to stop playing games and buy a brand new mini starter. Was very dissaponted that it too had interference issuues and finally it too was not engaging. So, back to the original cheapo AZ cheapo rebuilt which is where I'm at now. In 45 yrs, a starter has never given me so much bs, This is rediculous. Not going to badmouth the Mancini starter because Inever heard anything bad about them so I'm figuring it's me. But from the replies so far, I'm starting to be concerned about the Mancini unit because Inow own that sucker.
BTW it's a 130T in a 10 1/2 housing.
Re: What did I do wrong on my ministarter [Re: JohnRR] #968559
04/08/11 02:37 AM
04/08/11 02:37 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Not necesssarily true. I bought a Mancini mini-starter and ground it until I exposed the windings trying to make it fit. Mancini took it back and gave me a credit. I bought a 440 Source mini-starter and ended up grinding a little off my block to make it fit.
