Oil on valley pan #968347
04/07/11 10:25 AM
04/07/11 10:25 AM
Northern NJ
StukaJU87 Offline OP
Northern NJ
Yesterday, as I was taking a couple pics of my engine I noticed some oil on my valley pan. It appears to have run down from the passenger side where the intake bolts to the head nearest the firewall.
Forgive my ignorance, but would the bolt be wet in this area or is the valley pan not sealing correctly?
It's crappy out right now so I have to wait before I can examine it further.
Scott
1969 Super Bee, 383/4 speed
Re: Oil on valley pan [Re: StukaJU87] #968348
04/07/11 10:33 AM
04/07/11 10:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes the bolts that hold the intake are WET , meaning they will have oil to the backside of them. Check to see if they are loose, you might be sucking oil into those back ports.
You might want to pull the intake to have a look, quick fix might be to add one paper gasket between the intake and the valley pan, assuming you didn't already have to force in the bolts on one side the last time you put it on .
Re: Oil on valley pan [Re: StukaJU87] #968349
04/07/11 10:33 AM
04/07/11 10:33 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
yup. the intake manifold bolts go through the head into the open crankcase area, where oil can splash onto the back sides of the bolts. if the bolts are loose or something isn't lined up/sealed correctly, you could get oil seeping through the threads and dripping down the intake to the valley pan.
another option, is if you have excessive crankcase pressure from poor ring seal, or a plugged PCV valve, and the pressure bows up on the valley pan, this flexing will eventually cause it to crack, and then oil can seep through the crack and pool under the intake manifold.
**Photobucket sucks**
Re: Oil on valley pan [Re: 70Cuda383] #968350
04/07/11 10:42 AM
04/07/11 10:42 AM
Northern NJ
Northern NJ
I have 2 vented caps. The driver's side goes to the air cleaner and the passenger side is just a vented cap (soon to be replaced with a pcv valve hooked to the carb).
If I pull the bolt and it has oil on it, should I use some sealer on it?
Scott
Re: Oil on valley pan [Re: StukaJU87] #968351
04/07/11 10:53 AM
04/07/11 10:53 AM
Under My Car
Mopar_Country Offline
Under My Car
Can't hurt. I used sealer on all of my intake bolts. I applied it about a quarter inch up on the threads.
Re: Oil on valley pan [Re: StukaJU87] #968352
04/07/11 11:04 AM
04/07/11 11:04 AM
scratchnfotraction Offline
green nice job!
I have good luck with the loc-tite teflon pipe sealent,less clean up with R&R of the intake next go round.
all of the bolts are wet,nows the time.
Re: Oil on valley pan [Re: scratchnfotraction] #968353
04/08/11 09:26 AM
04/08/11 09:26 AM
Northern NJ
Northern NJ
green nice job!
I am gonna go out and do that in a little while. I think I have a tube of Permatex white in the garage.
WHAT would the torque be for the manifold bolts? Performer 440.
Scott
Re: Oil on valley pan [Re: StukaJU87] #968354
04/08/11 09:40 AM
04/08/11 09:40 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Make sure the pan is not cracked. It happens.
Re: Oil on valley pan [Re: GomangoCuda] #968355
04/08/11 09:42 AM
04/08/11 09:42 AM
Northern NJ
Northern NJ
Will do, but I don't think it is. The trail of oil comes from the bolt.
Still need the torque spec for intake bolts. 440 performer, stock heads, RB.
Scott
Re: Oil on valley pan [Re: StukaJU87] #968356
04/08/11 09:45 AM
04/08/11 09:45 AM
Check out the Tech Archives.http://www.moparts.org/Tech/Archive/motor/34.html
Re: Oil on valley pan [Re: GomangoCuda] #968357
04/08/11 09:47 AM
04/08/11 09:47 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
"snug, but not tight" is what I go with for intake manifolds.
I think most factory manuals call for around 30 ft lbs.
Re: Oil on valley pan [Re: StukaJU87] #968358
04/08/11 09:48 AM
04/08/11 09:48 AM
35-40 foot pounds IIRC
I am a back yard hack,so tight as i can with a 3/8 drive ratchet and call it good
or I use the 12" boxed end combo wrench by hand and pull them goodntight
Re: Oil on valley pan [Re: scratchnfotraction] #968359
04/08/11 09:50 AM
04/08/11 09:50 AM
Northern NJ
Northern NJ
Thank you!
Scott
Re: Oil on valley pan [Re: StukaJU87] #968360
04/08/11 10:31 AM
04/08/11 10:31 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Factory manual says 40 , just did it the other day
