Priming with a drill how many lbs? #967894
04/06/11 05:48 PM
04/06/11 05:48 PM
california
drumcat Offline OP
drumcat  Offline OP
california
How many lbs should i see pre-priming with a drill,Big Block.Thanks.
Re: Priming with a drill how many lbs? [Re: drumcat] #967895
04/06/11 05:51 PM
04/06/11 05:51 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
How many RPMs and power does the drill have ?
Re: Priming with a drill how many lbs? [Re: dOc !] #967896
04/06/11 05:57 PM
04/06/11 05:57 PM
california
drumcat Offline OP
drumcat  Offline OP
california
Not Sure on the RPM,s,craftsman 18.5 volt....slows to a crawl.
Re: Priming with a drill how many lbs? [Re: drumcat] #967897
04/06/11 06:04 PM
04/06/11 06:04 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
An 18.5 should have some grunt. But the better combo would be some-sort of a 1/2" corded drill.
EITHER way should get you good priming. Do you have an actual mech gauge on the car?
Re: Priming with a drill how many lbs? [Re: dOc !] #967898
04/06/11 06:07 PM
04/06/11 06:07 PM
california
drumcat Offline OP
drumcat  Offline OP
california
I do(in car) will use a mirror, our wait for some eyes is a fair bit of resistance expected from the drill?
Re: Priming with a drill how many lbs? [Re: drumcat] #967899
04/06/11 06:12 PM
04/06/11 06:12 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes it'll be very hard to turn, takes a lot of torque from the drill. 1/2" electric with a slow speed is best. You will see full pressure with the drill. Turn the crank a couple times too while running the drill. A battery operated drill don't stand a chance because it takes a lot of power to spin that oil pump with the oil cold.
Re: Priming with a drill how many lbs? [Re: drumcat] #967900
04/06/11 06:28 PM
04/06/11 06:28 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
In a pinch,even a speed handle works ok if your drill is too weak.
Re: Priming with a drill how many lbs? [Re: Challenger 1] #967901
04/06/11 06:30 PM
04/06/11 06:30 PM
california
drumcat Offline OP
drumcat  Offline OP
california
Thanks for the replies,everything sounds in order...on to wiring hell!
Re: Priming with a drill how many lbs? [Re: drumcat] #967902
04/06/11 07:09 PM
04/06/11 07:09 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Speed handle on my new small block, I was holding 50 lbs as we set it up.
If I went harder faster I could get 70.
Re: Priming with a drill how many lbs? [Re: boydsdodge] #967903
04/06/11 07:55 PM
04/06/11 07:55 PM
california
drumcat Offline OP
drumcat  Offline OP
california
Thanks for the numbers, I could use a bigger drill for sure.
Re: Priming with a drill how many lbs? [Re: drumcat] #967904
04/06/11 08:11 PM
04/06/11 08:11 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
My 10 year old Black and Decker 3/8 drill still works. I spin the prime stick fast enough to generate 70+ lbs in my 440/493.
Re: Priming with a drill how many lbs? [Re: drumcat] #967905
04/06/11 09:50 PM
04/06/11 09:50 PM
AndyF Offline
AndyF  Offline
You don't need a drill. I use a speed wrench and I don't have any trouble seeing 60 psi. A speed wrench works better anyway because you can get a "feel" for the oil pump. Big block motors often have a problem with the pump binding up so checking it by hand can save you a lot of grief down the road.
Re: Priming with a drill how many lbs? [Re: AndyF] #967906
04/06/11 11:10 PM
04/06/11 11:10 PM
Excellent point. I'm assuming you are going to turn it & hit both heads
Re: Priming with a drill how many lbs? [Re: RapidRobert] #967907
04/07/11 12:40 AM
04/07/11 12:40 AM
AndyF Offline
AndyF  Offline
Yes, TDC split overlap gets the passenger side, then rotate the crank 450 degrees to oil the driver's side.
Re: Priming with a drill how many lbs? [Re: AndyF] #967908
04/07/11 09:20 AM
04/07/11 09:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what he said, I did it at tdc roated it some hit it again rotated hit it again and rotated 1 more time. I used a good craftsman and it hit 70...runs at 80 until warm.
Coming soon!!!!
Re: Priming with a drill how many lbs? [Re: Mr.Yuck] #967909
04/07/11 10:36 AM
04/07/11 10:36 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I was using thick 20/50 oil, and a zinc additive on my last build. priming the oil pump burned out the 3/8" drive drill! (I mean, smoke coming out of the drill motor) I had to step up to a 1/2" drive drill.
**Photobucket sucks**
Re: Priming with a drill how many lbs? [Re: 70Cuda383] #967910
04/07/11 11:29 AM
04/07/11 11:29 AM
AndyF Offline
AndyF  Offline
Next time don't use a drill, just turn it by hand. You won't burn out the drill and you'll be able to verify that everything is working smoothly.
Re: Priming with a drill how many lbs? [Re: AndyF] #967911
04/07/11 12:28 PM
04/07/11 12:28 PM
North Seattle, Washington. USA
U code RR Online content
U code RR  Online Content
If you do use a drill, make sure it's turning in the right direction! I had a friend that tried and tried but couldn't get prime. He was sure he assembled something wrong. I went over to try to diagnose the problem and said "Try it this way", reversed the drill. BINGO! 75lbs. Did he feel dumb but relieved that he didn't have to go into the motor.
When seconds count... The Police are only minutes away. Smith and Wesson are your friends.
Re: Priming with a drill how many lbs? [Re: U code RR] #967912
04/07/11 01:51 PM
04/07/11 01:51 PM
WV,USA
W
wvmarv Offline
wvmarv  Offline
W
WV,USA
Congratulaions are in order for Jimmy Carter! You are no longer the worst President in the history of the United States of America! (although your still in 2nd place)
You got that right RR, George Bush beat him by a mile in that category.
Re: Priming with a drill how many lbs? [Re: drumcat] #967913
04/07/11 01:56 PM
04/07/11 01:56 PM
WV,USA
W
wvmarv Offline
wvmarv  Offline
W
WV,USA
Amount lbs doesn't matter until start up. Just make sure you have oil to all the rocker arms and your ready to go.
