833 23 spline Question #967451
04/05/11 11:57 PM
04/05/11 11:57 PM
Long Island, NY USA
BergmanAutoCraft Offline OP
Long Island, NY USA
I have a 23 spline A body unit dated June-73. How can I tell what gearset is in it. It has a 4.35 brg retainer, so I know its not an OD unit. Anyone?
Re: 833 23 spline Question [Re: BergmanAutoCraft] #967452
04/06/11 01:15 AM
04/06/11 01:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Look at the gears , they may have a number of notches cut across the tips of the gear teeth, but I think a 73 would be a 2.47 first gear.
Re: 833 23 spline Question [Re: BergmanAutoCraft] #967453
04/06/11 02:20 AM
04/06/11 02:20 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
This might help. I'll try and remember to look at the ones we have in the shed tomorrow.
http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
Re: 833 23 spline Question [Re: JohnRR] #967454
04/06/11 04:10 AM
04/06/11 04:10 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I thought that the 2.47 ratio was an E body, AAR or T/A application?
Re: 833 23 spline Question [Re: BergmanAutoCraft] #967455
04/06/11 07:38 AM
04/06/11 07:38 AM
Cleveland, OH
TWS Offline
TWS  Offline
Cleveland, OH
Re: 833 23 spline Question [Re: TWS] #967456
04/06/11 08:18 AM
04/06/11 08:18 AM
Long Island, NY USA
Long Island, NY USA
I've looked at all that. But its a July 73 unit and every ratio chart I read is different. I'll have to open the unit and look as per the pics on the Brewers site.
Re: 833 23 spline Question [Re: BergmanAutoCraft] #967457
04/06/11 08:56 AM
04/06/11 08:56 AM
Cleveland, OH
TWS Offline
TWS  Offline
Cleveland, OH
Try giving Wayne and Dan Brewer a call...I'm sure you can get it figured out pretty quickly over the phone.
Re: 833 23 spline Question [Re: TWS] #967458
04/06/11 10:07 AM
04/06/11 10:07 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
You can count the teeth on the input drive gear: 22 tooth 3.09 low, 24 tooth 2.66 low, or 25 tooth is 2.47 low gear. Could be 3.09 if it came from a 6cyl or 318, 2.47 from 340.
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 833 23 spline Question [Re: 64dodge572] #967459
04/06/11 03:04 PM
04/06/11 03:04 PM
Long Island, NY USA
Long Island, NY USA
Unfortunately its a 2.47 unit. Trying to figure the most economical way to make it a 3.09 unit.
Re: 833 23 spline Question [Re: BergmanAutoCraft] #967460
04/06/11 07:05 PM
04/06/11 07:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Find an early flanged output A body trans wit ha 3.09 gear and swap in the gears I think is your only , and possibly easiest, option ???
Re: 833 23 spline Question [Re: 68KillerBee] #967461
04/06/11 07:06 PM
04/06/11 07:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
bookmark this page ...
