Re: 833 23 spline Question
[Re: TWS]
#967458
04/06/11 10:07 AM
04/06/11 10:07 AM
Posts: 4,285 Ohio
64dodge572
Ohio
You can count the teeth on the input drive gear: 22 tooth 3.09 low, 24 tooth 2.66 low, or 25 tooth is 2.47 low gear. Could be 3.09 if it came from a 6cyl or 318, 2.47 from 340.
Wayne
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: BergmanAutoCraft]
#967460
04/06/11 07:05 PM
04/06/11 07:05 PM
Posts: 75,023 U.S.S.A.
JohnRR
U.S.S.A.
Unfortunately its a 2.47 unit. Trying to figure the most economical way to make it a 3.09 unit.
Find an early flanged output A body trans wit ha 3.09 gear and swap in the gears I think is your only , and possibly easiest, option ???
