whining noise in trans (?) with accel - 04 Jeep GC #967431
04/05/11 11:24 PM
04/05/11 11:24 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
My GF has a Jeep Grand Cherokee, the transmission makes a whining noise when it is under load (even slight); it sounded something like a pump cavitation, or like fluid going going through a small passage with air...
The trans is full...
It does not shift or do anything funny, but maybe shifts a bit late?
Any ideas?
Re: whining noise in trans (?) with accel - 04 Jeep GC [Re: 6T6Cuda] #967432
04/06/11 12:36 AM
04/06/11 12:36 AM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
What transfer case or is it 2-wheel drive.? What trans?
Re: whining noise in trans (?) with accel - 04 Jeep GC [Re: Geezer] #967433
04/06/11 09:52 AM
04/06/11 09:52 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Not sure of the trans, but it is has the 4.0, 4wd (it has the shift transfer case with full and part time and 4wd low).
Let me know if you need any more info...
Re: whining noise in trans (?) with accel - 04 Jeep GC [Re: 6T6Cuda] #967434
04/06/11 11:40 AM
04/06/11 11:40 AM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
Have the identical model.If you drive with the overdrive off with the trans in drive you will get a pronounced gear whine from the transfer case,the sound is very noticeable in the passenger compartment with the radio off.This is normal.If you have noise with the overdrive on it is back to the drawing board trying to pinpoint the area of the drivetrain the noise is coming from.
Re: whining noise in trans (?) with accel - 04 Jeep GC [Re: Geezer] #967435
04/06/11 11:47 AM
04/06/11 11:47 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Hello,
Thanks, will try it without overdrive... and report back...
