383 big block block and rotating assembly.. #967230
04/05/11 08:54 PM
04/05/11 08:54 PM
Fredericksburg,Virginia
1 Bad Duster Offline OP
I found a 383 big block with Eagle Crank H-beam rods and after market pistons.I was wondering what stroke cranks does eagle make for the 383s.The guy said it was a stock stroke but I couldn't find a 3.375 stroke that eagle made.. I found 3.75-3.91-4.15and 4.25stroker cranks. If its a 3.75 stroke that makes its a 426-432 bored 30 over right.
Re: 383 big block block and rotating assembly.. [Re: 1 Bad Duster] #967231
04/06/11 12:15 AM
04/06/11 12:15 AM
right
Re: 383 big block block and rotating assembly.. [Re: RapidRobert] #967232
04/06/11 01:26 AM
04/06/11 01:26 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
thats the same stroker job than a 400 being 451
Re: 383 big block block and rotating assembly.. [Re: NachoRT74] #967233
04/06/11 10:19 AM
04/06/11 10:19 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
yup, IF it's the 440 length stroke, it's the same set-up that turns a 400 into a 451
or, in that 383 it's a 426 at stock bore, 432 at .030 and 438 at .060.
if the block can take it, it's a 440 in 383 skin if you bore it to .070 over. but you can't use 440 pistons, because they'd be too tall.
as to whether or not the set-up you're looking at is a stroker or stock crank, you'll have to measure how much the pistons travel in the bore. I don't know what cranks were available and by who, but surely someone is making new, stock stroke cranks for the 383s.
**Photobucket sucks**
Re: 383 big block block and rotating assembly.. [Re: 70Cuda383] #967234
04/06/11 10:58 AM
04/06/11 10:58 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
except using lates smoggers 440s, where the CH is is just .004 higher than KB240s for 400s and KB162s for 383 which BTW sits around 0.010-0.020 down the hole. Thats another piston resource for us, 400 owners, and cheap. Just need to take 0.020 more on the bore
I think skirts should be revised though
Re: 383 big block block and rotating assembly.. [Re: NachoRT74] #967235
04/06/11 07:48 PM
04/06/11 07:48 PM
Thanks for all the reply's. It comes with everything Eagle crank,Eagle H-beam rods,Pistons for the block but no sure what kind.
1973 Pro Street Duster
Re: 383 big block block and rotating assembly.. [Re: 1 Bad Duster] #967236
04/06/11 08:37 PM
04/06/11 08:37 PM
If this is a short block measure the piston travel from TDC to BDC for the stroke & only several common stroker dimentions so should be able to match a common one to what you get as close as you can w a 6" steel ruler
Re: 383 big block block and rotating assembly.. [Re: RapidRobert] #967237
04/06/11 10:08 PM
04/06/11 10:08 PM
Its a short block but I still Have to put it together.Its new still in the box.I'am hoping it at least a 3.75 stroke. I haven't found anywhere that Eagle makes a 3.375 stroke crank..
Re: 383 big block block and rotating assembly.. [Re: 1 Bad Duster] #967238
04/06/11 10:13 PM
04/06/11 10:13 PM
lay the crank in it's side and make a magic marker mark @ 12 o'clock on a main journal and on an adjacent rod throw then measure the (offset) distance between the two. that's the "throw" distance and double that for the stroke ie an offset distance of 2&1/8 would b a 4.25" stroker
Re: 383 big block block and rotating assembly.. [Re: RapidRobert] #967239
04/06/11 10:31 PM
04/06/11 10:31 PM
Ok thanks for the help.
