measuring for pushrods with hydraulic lifters
#967158
04/05/11 08:18 PM
04/05/11 08:18 PM
Posts: 3,415 Toronto
mshred
Toronto
Hey guys, Just wanted to ask about measuring pushrod length with hydraulic lifters. I am running a hydraulic roller cam and when trying to set the pushrod length with my adjustable pushrod, the lifter would bottom out (they are not pumped up, there is no oil in them). I am not running a checker spring, which I know is one of the answers to this. I was thinking of just allowing it to bottom out and then add the .030-.040" or so to the overall length of the pushrod to compensate for the preload...has anybody done this before? I was also planning on possibly removing the guts out of the lifter and filling it with small nuts or flat washers stacked up, reinstall the top cover and retainer spring, so that to make it act like a solid lifter, and then check my findings on length compared to with just letting the lifter bottom out. What have you guys done or suggest? I know a checking spring or possibly a junk solid lifter would be ideal, but i dont have access to the springs or lifters, plus my hydraulic roller lifter is a good deal taller than a comparable solid lifter if i had to buy one What have you guys done that works? I'd like to do this tommorow so I can order up some pushrods and get this motor completely together
Re: measuring for pushrods with hydraulic lifters
[Re: runner12]
#967161
04/05/11 09:17 PM
04/05/11 09:17 PM
mshred
Toronto
Go to HUGHES ENGINES .COM they have a tech sheet you can click on
I should have been more clear in my original post. I am going by their instructions titled "Rocker arm gemoetry and pushrod length for custom pushrods". It is quite a long process, although it is accounting for rocker geometry as well. I have already checked for that and I am good to go However, in the article they are using a checking spring, and they don't mention anything different in the procedure if using hydraulic lifters and no checking spring
[Re: Stanton]
#967162
04/05/11 09:21 PM
04/05/11 09:21 PM
mshred
Toronto
What the hell are ya doin' ?!?!
Checker springs don't even come in to play here.
1) get a lifter on the base circle 2) install a head with gasket and cinch down 3) install one rocker on a shaft and cinch down 4) if rocker is adjustable, set adjuster so 2 threads are showing 5) install checker pushrod and adjust until only the slack is taken up between the lifter and adjuster - do this by "feel", don't tighten so much as to compress the lifter.
You're done.
LOL im just doing what the Hughes tech sheet says since im using their 1.6 rockers and I have never done this before
I am using their 1.6 adjustable rockers, and in their tech sheet it says nothing about adjuster thread length, just to set the adjusting screw so that the ball is protruding .450" from the rocker body (smallblock LA spec)
My lifter was only compressing and bottoming out as I was turning the motor over so as to check rocker geometry and pushrod length like the article says...The method you posted seems to be pretty easy compared to what they are saying though. In the method you posted, how do I account for lash? please go easy on me, im just learning this stuff as I go
[Re: 440Jim]
#967165
04/05/11 09:47 PM
04/05/11 09:47 PM
mshred
Toronto
With a hydraulic lifter, my rule of thumb is to set it up for the lifter to be compressed between 0.010-0.030". This requires a lot of care to make sure that distance is from just touching zero lash.
So is your method similar to Stanton's above post? Im assuming you are using a lifter with no oil in it and set it by feel as well?
[Re: cgall]
#967166
04/05/11 09:48 PM
04/05/11 09:48 PM
mshred
Toronto
I used a solid lifter. And I set my lash at zero.
Like my original post says, I don't have access to a solid lifter, which is why I was thinking about shimming up an empty hydraulic lifter..plus my hydraulic lifter is a roller which is taller than a standard solid lifter, although your method would make my life alot easier lol
[Re: mshred]
#967167
04/05/11 09:59 PM
04/05/11 09:59 PM
Posts: 7,506 Az
Crizila
Az
From what I remember their method is kinda long and drawn out - they tried to make it rocket science . The 2 threads showing thing is probably about the same as their .450". You can't use a hydraulic lifter ( even if it's filled with oil and/or you are using a light spring. I use a "checking lifter" that has the push rod plunger replaced with one that can be screwed up and down. You can do the same thing with a junk Hydraulic lifter as you said. Fill it with washers until you get the height you want - which will be the same as the lifters you will be using less what ever preload you want to use. I run a large ( over .6" ) hyd flat tappet cam. I took my adjustable lifter and set it beside the lifter I will be using. Put pushrods in both lifters. Adjusted my checker lifter so that both pushrods were the same height. I like to use a preload of 1/4 turn ( sorry I can't remember exactly what tha is in thousands of an inch - probably around .015" ) . That way if I accidentally pump them up ( over rev ), I don't bend stuff. You will have to use what ever your cam MFG recommends or what ever and fill your checking lifter with junk until you get to the stock height, less what ever preload you want to run. Hope this helps.
Fastest 300
[Re: Crizila]
#967168
04/05/11 10:35 PM
04/05/11 10:35 PM
Posts: 16,928 NC
440Jim
NC
For an adjuster with 3/8-24 threads, each turn is 1/24=0.0417". So 1/4 turn would be 0.010"
That is a good performance setting, IMO.
[Re: Crizila]
#967169
04/05/11 10:38 PM
04/05/11 10:38 PM
mshred
Toronto
thanks for the info! I kinda figured the Hughes method was a bit of overengineering, but it didnt hurt to use their method to atleast get my rocker geometry correct. I don't think my cam card had a spec for preload/lash on it but i will double check.
[Re: mshred]
#967170
04/05/11 11:26 PM
04/05/11 11:26 PM
Posts: 8,880 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
A-HA ! Now I understand ... I didn't realize you were checking the geometry too!
As for the "adjuster protruding .450", that's pretty much what I was getting at with the "two threads showing" statement.
Anyhow,, you don't need to use the lifter/pushrod to check geometry - with the checker springs installed you can just move the rocker through its approximate amount of travel by hand and watch the geometry.
Here's a tip that I just discovered while checking my own about a half hour ago ... check BOTH intake and exhaust (in case they have different base circles like mine has!!)
I wouldn't worry about lash or preload - that's a minimal amount that can be taken up by the adjuster, .010" is not an amount to be worried about.
[Re: Stanton]
#967171
04/06/11 04:27 PM
04/06/11 04:27 PM
Posts: 14 ILL
Roger 68 Charger
ILL
So if the geometry is not perfect what would be your options?---
[Re: Stanton]
#967173
04/07/11 09:20 PM
04/07/11 09:20 PM
mshred
Toronto
Unfortunately I don't have a checking spring available, so I would technically have to shim up my lifter...But my geometry is good
thanks for all the help everybody! Gonna tackle this tommorow so i can get those pushrods ordered and finally button up the rest of this motor
[Re: mshred]
#967174
04/07/11 11:41 PM
04/07/11 11:41 PM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
wouldnt it just be easier to make an adjustable pushrod out of an old one,cut it,tap it and put a threaded rod in it.Then just put it in adjust to zero lash and give it your 1/4 or half turn.Then turn the engine over and see how the arm rides on the valve.If its off just readust the rocker arm adjusting bolt higher or lower and reset the pushrod to make it ride correctly.when your happy just measure the pushrod and order it that size.
[Re: mshred]
#967177
04/08/11 05:37 PM
04/08/11 05:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The engine is an LA with a bone stock bottom end...
I got the pushrods all measured up today, but ran into bigger issues...the intake valve on the heads is deep into the piston, so it looks like im going to be making a piston fly cut tool with the old heads and putting notches into the stock pistons...kinda worried though as to how thick these pistons are
First... what is the cam installed at and what is the LSA.... as to the geometry of the rockers... the push rod dosent change that... you need to raise or lower the rocker shaft to do that
[Re: MR_P_BODY]
#967179
04/08/11 07:23 PM
04/08/11 07:23 PM
mshred
Toronto
the cam is a 106 LSA installed straight up on a 101 intake centerline
I wasnt referring to the geometry of the rockers. My intake valves are hitting the piston big time when I turn the motor over to check piston to valve. So much so that the valve is cutting into the piston and vice versa. I checked the exhaust valve the same way and its fine...im thinking the combination of the larger intake valve than stock (2.02 vs. 1.88) and the high lift on the cam with small 62cc chambers in the heads and the lack of valve reliefs in factory pistons is what culminated in this.
[Re: Stanton]
#967180
04/08/11 07:26 PM
04/08/11 07:26 PM
mshred
Toronto
1) You said you checked the geometry and its ok, right?
2) You said you don't have checker springs and you're using hydraulic lifters. So, how have you determined the intake valve "is deep" in the piston? Are you checking this with the cam installed where you want it and turning the motor over by hand with clay in the piston?
"deep" means squat ... its the actual piston to valve clearance through a normal cycle that matters.
Yes the cam is installed where I want it. Im using a lifter that I shimmed up inside so that it acts like a hydraulic lifter with about .080" of preload. The pushrod length part and rocker geometry is fine
What I meant by the valve being deep into the piston is that when I am checking with clay for piston to valve and turning the engine over, the intake valve is actually cutting into the piston
I should have been more specific...i used to the word deep instead of "cutting in" to make myself feel better in my head...I was hoping today to bolt the heads on, but its a darn good thing i checked for this...atleast im learning everything about engine building now lol
[Re: MR_P_BODY]
#967182
04/08/11 08:11 PM
04/08/11 08:11 PM
mshred
Toronto
Your cam is not straight up... you have it installed 5* advanced... still shouldnt be hitting.... have you measured yet how much its crashing... why dont you give use all the specs on the cam and the pistons... also did you check the balancer when you installed the cam
the cam has 5 degrees advance ground into it which is why 101 is straight up (This is what I was told before having the cam ground). The balancer is not on the engine yet, I degreed the cam with the heads off and the balancer off using the intake centerline method and the intake/exhaust open/close method as well.
As far as piston specs go, I really don't have any on them. They are stock 91 LA pistons that came with the motor, factory dished, with no valve releifs. I would say the dish is anywhere from 5-7cc as its not very deep. The chambers on the heads are 62cc
The cam specs are for installed at 101 intake centerline Duration at .50"- 230/230 Lobe lift (at the valve with 1.6 rockers)- 577/569 Lobe seperation- 106 valve timing at .050 open close Int: 14 BTDC 36 ABDC Exh: 46 BBDC 4 ATDC
what do you think?
[Re: mshred]
#967183
04/08/11 08:20 PM
04/08/11 08:20 PM
MR_P_BODY
the cam has 5 degrees advance ground into it which is why 101 is straight up (This is what I was told before having the cam ground). The balancer is not on the engine yet, I degreed the cam with the heads off and the balancer off using the intake centerline method and the intake/exhaust open/close method as well. As far as piston specs go, I really don't have any on them. They are stock 91 LA pistons that came with the motor, factory dished, with no valve releifs. I would say the dish is anywhere from 5-7cc as its not very deep. The chambers on the heads are 62cc The cam specs are for installed at 101 intake centerline Duration at .50"- 230/230 Lobe lift (at the valve with 1.6 rockers)- 577/569 Lobe seperation- 106 valve timing at .050 open close Int: 14 BTDC 36 ABDC Exh: 46 BBDC 4 ATDC what do you think?
Its still 5* advanced... maybe you are referring to what they wanted it installed at(101)... without the balancer on the engine how did you reference the crank... I think you have the cam in wrong... that cam and those pistons shouldnt hit
[Re: MR_P_BODY]
#967184
04/08/11 08:31 PM
04/08/11 08:31 PM
mshred
Toronto
what do you think?
so if i retard the cam then I would gain piston to valve clearance? how does that work? What effects on performance would retarding the cam have, and would retarding it 5 degrees help me gain the clearance i need?
I lined up the timing gear marks for straight up on the timing set and found top dead center with a dial indicator on #1 piston as outlined in all the instructions i have ever found i.e. hughes engines, comp cams, my mopar hotrodding book. According to all my calculations and where this cam is supposed to be installed (Straight up at 101) the timing gear and my install are correct.
Please don't take this as me being sure...I am doing all of this for my first time and am still learning. I would really rather not flycut the pistons, but im not sure what else to do...I don't want to compromise performance in an already low compression motor by retarding the cam
[Re: mshred]
#967185
04/08/11 08:42 PM
04/08/11 08:42 PM
MR_P_BODY
so if i retard the cam then I would gain piston to valve clearance? how does that work? What effects on performance would retarding the cam have, and would retarding it 5 degrees help me gain the clearance i need? I lined up the timing gear marks for straight up on the timing set and found top dead center with a dial indicator on #1 piston as outlined in all the instructions i have ever found i.e. hughes engines, comp cams, my mopar hotrodding book. According to all my calculations and where this cam is supposed to be installed (Straight up at 101) the timing gear and my install are correct. Please don't take this as me being sure...I am doing all of this for my first time and am still learning. I would really rather not flycut the pistons, but im not sure what else to do...I don't want to compromise performance in an already low compression motor by retarding the cam
First off you really dont know where its installed at... get a degree wheel on it... forget about the dots they can be way off... just because you lined up the dots doesnt mean its straight up... you are at 5* advanced from something... when the intake is at full lift the crank (degree wheel) will say 106*, thats straight up..... yes when you advance/retart the cam it changes the valve to piston clearance... you should get a buddy over to help you install it and show you how.... I wonder if you used the exhaust valve instead of the intake EDIT did you clay the piston just to make sure it isnt hitting the lip of the piston... just checking
[Re: MR_P_BODY]
#967186
04/08/11 09:00 PM
04/08/11 09:00 PM
mshred
Toronto
I used a degree wheel man...i have followed the instructions to a T...and no, I measured the intake, not the exhaust valve. I know the difference between the two...I said im still learning, not that im stupid lol
Im gonna talk to Brian about this since he did my cam and heads and see what he thinks about retarding these cam specs on my motor...id much rather do that then flycut the pistons
[Re: mshred]
#967189
04/09/11 10:21 AM
04/09/11 10:21 AM
MR_P_BODY
Hey Mr. P., sorry if i came across like an ass last night, was just a bit flustered with the whole situation and some other stuff that has just put me in a not so good mood lately...everything you asked and stated was valid, and I appreciate you trying to help me out. I think I have this figured out now and I will post up my results as soon as I get them Going to retard the cam so that its installed straight up on and see what happens
thank you
No biggie... get some clay and see if the valve is hitting the edge of the piston
[Re: MR_P_BODY]
#967190
04/10/11 03:08 PM
04/10/11 03:08 PM
mshred
Toronto
well I have since done this... retarded the cam using the 4 degree key way on my Cloyes True Street roller timing set and degreed the cam as well...Cam actually retarded all the way from 101 ICL to a 108ICL, so 7 degrees, which is two degrees retarded past straight up (So much for the accuracy of the keyways). At this point I figure heck, i'll have miles of PTV clearance. I have been checking PTV with one of my hydr. lifters shimmed up to have .080" preload, and readjusted pushrod length for best geometry and maximum lift. I checked PTV with 0.036" shims to simulate an in between of the two gaskets I have available (0.028" compressed or .050" compressed). My findings were less than stellar... Even after all that retarding, the exh. PTV was .150", while int. PTV was at best .065"..however, my problem is that I am using a dial indicator on the retainer to assure im getting max lift when checking PTV, but max lift keeps changing anywhere from 549-555" on the int...im assuming this is because the needle will never be perfect on the retainer, but it is fudging up my readings on the clay- there seems to be lots of clearance within the dish, but where the dish raises up to the flat part of the piston is where its close...some of my clay readings were around .030" still! Its all over the place! My plan is to call Brian and discuss my options with him, and also to pick up a checking spring from the hardware store and try a little bit of a different method to check PTV...at this point im starting to get flustered as im not sure what else to do- i really dont want to cut the stock cast pistons just a few specs for thought...my heads are 62cc, cam is 577int/ 569" exh lift according to the cam card using Hughes 1.6 rockers, pistons are below deck about .083", dish has no valve releifs and is in the 5-7cc area, with stock bore and stroke for a 360 (4.00 x 3.58). Im learning alot through all this...im also getting large headaches lol
[Re: Stanton]
#967192
04/10/11 03:47 PM
04/10/11 03:47 PM
mshred
Toronto
Rocker shafts are loose or flexing causing the variance in lift. Possibly even the indiator arms are moving slightly (not uncommon).
Also, .080 is too much preload on the lifter, it should only be something like .010 to .025 (I believe). Personally, if it were me, I'd be setting things up with ZERO preload and allowing that as a safety buffer when things finally go together.
You have a head gasket in there, right? What's your calculated compression right now? What will it be if you increase the head gasket thickness to gain PV clearance? If that's even an option!!
I will check the tightness of the rockers. They are tight when i put them on, but i will double check them.
I set the lifters to .080" preload as thats what Hughes Engines said when I called and talked to Kevin. Im using Hydraulic roller lifters, not flat tappet, so thats where the difference is. He told me I won't gain anything going lower than that, all that I will get is more noise. Im also doing all these checks with zero lash
I don't have a head gasket in when I am checking this. I have been using .036" shims since I kinda didnt want to use up a set of gaskets, but i think im just going to bite the bullet and use a set...however, at this point im also not sure which set i will use- I have a set of the mopar .028" thin gaskets to get compression up (this is a bone stock bottom end so i could use all the CR boost I can get) and the felpro 8553 permatorques which are around .050" compressed from what others have said
calculating with the my current head combo, bore, stroke, 0.083 deck clearance, 5-7cc dish on the pistons, and .028" head gasket thickness, im looking at about 9.1:1 CR....Id really rather not go to the thicker gasket since I will be around 8.8:1, but I will if I have to
[Re: mshred]
#967193
04/10/11 03:54 PM
04/10/11 03:54 PM
MR_P_BODY
Use your thin head gasket but just snug it to about 40-50 LBS that way you can still use them... try not to retard the cam, with your low comp and late valve closing it would make it a MUTT
[Re: MR_P_BODY]
#967194
04/10/11 03:57 PM
04/10/11 03:57 PM
mshred
Toronto
But Mr. P, I was getting insane valve to piston smack before. Still think I should try with the gasket and installing the cam back at 101 (where the 5 degrees advance were ground in). If i try it here again and im still getting PTV contact, what is the issue and what is the fix?
I was worried about retarding the cam so much as well in terms of the effects on performance like you mentioned, but figured it was my only option
[Re: Stanton]
#967195
04/10/11 05:29 PM
04/10/11 05:29 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I should hope so! Tell me how you would preload a lifter .080 and then put in lash ?!?!?!
I gotta believe that anything you read regarding checking PV clearance told you to mock things up as you would run it ... INCLUDING HEAD GASKETS. Get 'em in there, you've been wasting your time without them.
[Re: Stanton]
#967196
04/10/11 08:18 PM
04/10/11 08:18 PM
mshred
Toronto
your probably right, and yes, I will be checking with the gaskets next time I get at it.
