I've done a search, but what is the best tranny fluid? #966877
04/05/11 01:55 PM
04/05/11 01:55 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I need to do a flush & fill on my 70 Coronet R/T and I'm planning on ordering a PAIL of transmission fluid. I've used Shaefers in the past after reviews on Bobsistheoilguy forums and have been VERY happy with it...
But what do I put in my 727? The car has about 130K miles on it and I dont know if the tranny has ever been serviced, but the fluid has NO burnt smell and is a good *color* of red.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: I've done a search, but what is the best tranny fluid? [Re: shanker] #966878
04/05/11 02:59 PM
04/05/11 02:59 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'm curretnly running Havoline Type F in mine. Its behind a 500 hp 451 with a 10" 3500 converter.... Seems to be doing just fine.
Re: I've done a search, but what is the best tranny fluid? [Re: StealthWedge67] #966879
04/05/11 03:03 PM
04/05/11 03:03 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
The consensus here is usually a Type F style. There are so many to chose from though. I run Redlines Type F.
Re: I've done a search, but what is the best tranny fluid? [Re: Viol8r] #966880
04/05/11 03:23 PM
04/05/11 03:23 PM
Under My Car
Mopar_Country Offline
Under My Car
Type F is supposed to have better lubricating properties and helps firm up the shifts.
Re: I've done a search, but what is the best tranny fluid? [Re: shanker] #966881
04/05/11 03:35 PM
04/05/11 03:35 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Type F. Running it for years.
Re: I've done a search, but what is the best tranny fluid? [Re: DusterKrazy] #966882
04/05/11 03:40 PM
04/05/11 03:40 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Type F
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: I've done a search, but what is the best tranny fluid? [Re: BloFish] #966883
04/05/11 09:11 PM
04/05/11 09:11 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
hmm.... http://www.schaefferoil.com/204_transmission_fluid.html
I gotta find out if its Type F compatible..
Re: I've done a search, but what is the best tranny fluid? [Re: Mopar_Country] #966884
04/05/11 09:25 PM
04/05/11 09:25 PM
the house on the left.
cogen80 Offline
cogen80  Offline
i thought it was grittier (sp?) which is supposed to firm up the shifts. in my opinion thats an oldhead thing. with the materials and parts they have now type f is not needed. dextron is fine.
Re: I've done a search, but what is the best tranny fluid? [Re: cogen80] #966885
04/05/11 10:56 PM
04/05/11 10:56 PM
IMGTX Offline
IMGTX  Offline
Type F, Dextron, Mercon etc all have basically the same lubricating properties but have different friction modifiers. The friction modifiers cause the clutches to slip a little on engagement and lessen harsh shifts. Type F has less friction modifiers and therefore shifts are firmer. Ford designed their transmissions around that fluid that is why a Ford with Type F shift like a Dodge with Dextron, but a Dodge with type F shifts firmer.
Be cautious of the newer fuids because they are loaded with extra friction modifiers and are very slippery. The lockup convertors are very harsh on lockup if you don't have them. Some of the newer transmissions require CVT fluids and such.
For older stuff like ours I like type F. It is as close to the Dextron II that they were designed for as you will get these days. Often mix it with the current flavor of Dextron.
My
