1968 CUDA #966791
04/05/11 12:16 PM
04/05/11 12:16 PM
OHIO,USA,43154
johnl1961 Offline OP
OHIO,USA,43154
SO I BUY A CUDA ON EBAY TO PART OUT AND THE VIN ON DASH IS NOT THE SAME AS BODY!THE BODY CODE IS M8B NOT F8B WHICH IS 318 CAR SO WHAT IS A M CODE
Re: 1968 CUDA [Re: johnl1961] #966792
04/05/11 12:41 PM
04/05/11 12:41 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The VIN in not on the body in '68, you're looking at the SO# which can be found on the fender tag.
BTW, your 'caps lock' key is on.
Re: 1968 CUDA [Re: B5 Bee] #966793
04/05/11 12:46 PM
04/05/11 12:46 PM
OHIO,USA,43154
OHIO,USA,43154
On the core support on drivers side there are M8B196631 So i know those have to be body #s right?
Re: 1968 CUDA [Re: johnl1961] #966794
04/05/11 12:53 PM
04/05/11 12:53 PM
USA
rftroy Offline
rftroy  Offline
USA
No.
As B5Bee said, that is the sales order number. VIN not on car in '68; it's not on the fendertag, it's not stamped on the body. It only appears on the windshield VIN plate.
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: 1968 CUDA [Re: rftroy] #966795
04/05/11 12:59 PM
04/05/11 12:59 PM
OHIO,USA,43154
OHIO,USA,43154
You guys are more in the know than i am but i also have a 1968 dart GTS h code car it has the body numbers on the core and cowl!Thats why i looked and as i said the numbers are not the same.
Re: 1968 CUDA [Re: johnl1961] #966796
04/05/11 01:04 PM
04/05/11 01:04 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
So what Info. can you get from the numbers on the core support, if any
Re: 1968 CUDA [Re: roadhazard] #966797
04/05/11 01:10 PM
04/05/11 01:10 PM
OHIO,USA,43154
OHIO,USA,43154
stamped m8b196631
Re: 1968 CUDA [Re: johnl1961] #966798
04/05/11 01:18 PM
04/05/11 01:18 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
So the VIN is F8B196631 and the core number is M8B196631?
Re: 1968 CUDA [Re: B5 Bee] #966799
04/05/11 01:33 PM
04/05/11 01:33 PM
OHIO,USA,43154
OHIO,USA,43154
no vin tag is f8b113724
Re: 1968 CUDA [Re: johnl1961] #966800
04/05/11 05:54 PM
04/05/11 05:54 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
mines 8B113554 and i know of 8B113558..[both formula S ragtops] is it a northwest sold new car? dan
Re: 1968 CUDA [Re: ph23vo] #966801
04/05/11 07:30 PM
04/05/11 07:30 PM
OHIO,USA,43154
OHIO,USA,43154
dont know cause no title
Re: 1968 CUDA [Re: johnl1961] #966802
04/06/11 12:06 PM
04/06/11 12:06 PM
Wheatfield, NY
Cuda340 Online work
Cuda340  Online Work
Wheatfield, NY
Can't help on the original question but the car has a 1969 'Cuda fender on it. It is the same as a regular fender but it has the lower body stripe. Pretty neat. Just an observation, sorry, Carry on!!
