VIN# #966648
04/05/11 09:24 AM
04/05/11 09:24 AM
ILL
Roger 68 Charger Offline OP
ILL
I was looking at the VIN# on my 70 cuda and the first two #s are RS--
When I looked this up the R stands for Belvedere/satelite --Is this
right?
68 RT charger 70 Cuda 99 Durango
Re: VIN# [Re: Roger 68 Charger] #966649
04/05/11 09:29 AM
04/05/11 09:29 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Are you sure? You may wanna take a closer look.. The "R" and "B" may be very similiar. Do you have the fender tag for the car? If so, does the Seq# (last 6 digits) match the 6 digits on the bottom row, right side of the tag?
Troy
Houston Mopar Connection Club
Re: VIN# [Re: hemi68charger] #966650
04/05/11 10:31 AM
04/05/11 10:31 AM
MId West
wasacuda Offline
wasacuda  Offline
MId West
FACTORY VIN MISPRINTS DO HAPPEN. I HAVE HAS A FEW OVER THE YEARS. I JUST SOLD A 71 CHALLENGER R/T WITH A VIN BOO BOO. IT WAS JS23HIB INSTEAD OF JS23H1B.
Re: VIN# [Re: wasacuda] #966651
04/05/11 10:36 AM
04/05/11 10:36 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
what's that ??? I CAN'T HEAR YOU ???
That I can see but putting RS on a BS when they were not built at the same plant ... more than likely ... ????
Re: VIN# [Re: JohnRR] #966652
04/05/11 11:48 AM
04/05/11 11:48 AM
Newfoundland
Crocker Offline
Crocker  Offline
Newfoundland
the last 6 digits of your vin is stamped (1)on the top of the cowl, near the drivers side wiper post and (2)in the radiator mount yoke. If the numbers match, you most likely got a misprint in the vin tag
Re: VIN# [Re: Crocker] #966653
04/05/11 12:40 PM
04/05/11 12:40 PM
ILL
ILL
I could not read the fender tag so I pulled it off to look at the back side and the last 6#s of the VIN match the numbers on the lower right of the fender tag
I found the title and the VIN# starts with a RS and has 1970 Plymouth Satalite I called the Sec Of State and they said If I bring down the car and all the #s match they can change it to say Cuda
When I get home I will have to check the cowl and see if I can find the #s
I Have had the car for 18 yrs and been in storage for the last 14--when I bought the car I didnt think about ckecking any #s--all I remember was that I was getting a 70 CUDA
Re: VIN# [Re: Roger 68 Charger] #966654
04/05/11 01:18 PM
04/05/11 01:18 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
That may be a drag getting that straightened out. I sold a car out of state last year that had a title typo,(6th digit year code showed a "Z" instead of the correct "2") so I had to go to sec of state a couple of times, and they had tracked it down to a mistake by the currency exchange I transferred at 3 years prior. So it was kindof my fault for not catching it.
Re: VIN# [Re: Roger 68 Charger] #966655
04/09/11 02:14 PM
04/09/11 02:14 PM
Finland
CarelianCuda Offline
Finland
It's not a Satellite, it's a GTX.
That means at only possible engine codes are U, V and R
Also assembly plant code is different than E-body, as earlier mentioned.
So it's quite easy to see is it misprint or GTX title, at least after you find the cowl numbers
1970PlymouthCuda383
1970AMCHornet2D232
2003TruckmastersOkenosDurangoSlt+
2008DodgeChallengerSRT8
