727 no 1st gear in D #966557
04/05/11 01:52 AM
04/05/11 01:52 AM
The Pale Blue Dot
Skeptic Offline OP
Skeptic  Offline OP
The Pale Blue Dot
In manual low it works fine. Just rebuilt, with the TF-2 vbody kit and bouchillon kickdown. The FSM doesn't have this issue in the troubleshooting, nor does the 727 Handbook (that I could find)
Some help or direction on what to check would be greatly appreciated.
Re: 727 no 1st gear in D [Re: Skeptic] #966558
04/05/11 02:08 AM
04/05/11 02:08 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Sprag failure? Were the springs and rollers installed correctly?
Re: 727 no 1st gear in D [Re: 451Mopar] #966559
04/05/11 02:24 AM
04/05/11 02:24 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Me thimks someone might have left them out ...
It has happened before.
Re: 727 no 1st gear in D [Re: Skeptic] #966560
04/05/11 08:03 AM
04/05/11 08:03 AM
New Zealand
Big-Mike Offline
Big-Mike  Offline
New Zealand
If it takes off fine in Low Gear, but seems like its in Neutral when you shift into 2nd or top, it will be the governor on the tail-shaft behind the speedo spline. It will be jammed & not moving outwards with the centrafugal force of revs.
I had this happen years ago.
Re: 727 no 1st gear in D [Re: Big-Mike] #966561
04/05/11 12:11 PM
04/05/11 12:11 PM
The Pale Blue Dot
Skeptic Offline OP
Skeptic  Offline OP
The Pale Blue Dot
1-2-3 are fine manual, comes off the line in 2nd gear, then upshifts into 3rd. R works fine.
Re: 727 no 1st gear in D [Re: Skeptic] #966562
04/05/11 12:58 PM
04/05/11 12:58 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
When you throw it into manual low, the low/reverse band applies in addition to the rear clutch.
In drive, you are reliant on the roller clutch and rear clutch
Sounds to me like the roller clutch isnt holding the reverse drum.
Anyway, you've proven that the rear clutch and low/reverse band work if you have manual low. This also is confirmed since you have reverse.
Sounds to me like the roller clutch is where you're going to find your problem.
Someone correct me if I am wrong. I'm just trying to envision this in my head...that's the picture I have.
Re: 727 no 1st gear in D [Re: POS Dakota] #966563
04/05/11 03:18 PM
04/05/11 03:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No you are correct , but he may have a valvebody issue that is causing it to start in 2nd gear
Re: 727 no 1st gear in D [Re: JohnRR] #966564
04/05/11 05:23 PM
04/05/11 05:23 PM
The Pale Blue Dot
Skeptic Offline OP
Skeptic  Offline OP
The Pale Blue Dot
Oh snap. I was pretty careful putting that thing together, but stuff happens. I'll have to get it torn down and check the sprag. If there's any problem I'll just go with a bolt in unit. Thanks, Steve
Re: 727 no 1st gear in D [Re: Skeptic] #966565
04/05/11 05:35 PM
04/05/11 05:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If the outer race is NOT spun the std. bolt in is a waste of time and money, it does nothing to correct the potential problem of the rollers rolling over , it's function is to repair a stripped case. The only way to fix the rollers rolling over is with a super or ulitmate sprag .
