Edelbrock carb question #966173
04/04/11 09:24 PM
04/04/11 09:24 PM
USA
JoesMopar Offline OP
USA
I am getting ready to place an order and am needing advice on the 650 Thunder Series carb
I am using the performer RPM intake on a 383 and 727 combo.
The car right now has the original 318 and 2bbl carb.
Is there any special linkage or anything to make this carb work on my '68 b body? Specifically a throttle adapter or for the electric choke?
Re: Edelbrock carb question [Re: JoesMopar] #966174
04/04/11 09:30 PM
04/04/11 09:30 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You'll need the mopar specific throttle adapter that bolts up to the side of the existing linkage.
Choke only needs a power source to work on any vehicle.
I'd bet that some of your 2 barrel throttle and kickdown linkage needs replaced with 4 barrel specific linkage too.
Re: Edelbrock carb question [Re: JoesMopar] #966175
04/04/11 09:32 PM
04/04/11 09:32 PM
I think you can use the OE throttle adapter from the 2bbl, the one w the pin and the nut that screws on/secures it. If you have a functioning heat riser I'd suggest useing an OE thermostatic choke in the well. At least on my eddy 1406 the elec choke comes off way too fast and b 4 that the choke pulloff is inop but haven't dug into it yet. EDIT Roe is right, forgot about that, also need the horsehoe shaped bracket for the pin/nut to bolt into. The one for a holley is slightly different (bolt hole C to C) from the eddy one but I think you can easily redrill the carb linkage hole slightly next to it for a holly one to fit if you happen to have one but those adapters are cheap. O'reilly's or a similar parts house that has an Eddy carb accessories will have it & iirc less than $10
Re: Edelbrock carb question [Re: JoesMopar] #966176
04/04/11 09:32 PM
04/04/11 09:32 PM
Central TX
roe Offline
roe  Offline
Central TX
I am definately no carb expert, but I went from a 318/904 2bbl to a 360/904 4bbl. I had to pick up a 4bbl kickdown linkage setup, complete with the throttle position lever that bolts to the trans, and make adjusting bends in the bar that runs from the carb to the trans lever. With the help of guys here I was able to get my cobbled mess straightened out, and get my shift points set correctly. There is a throttle adapter bracket for Mopars but I set mine up without it and all is well. I did order one, but never put it on because I didnt want to have to re-bend the bar in the kickdown linkage.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Edelbrock carb question [Re: roe] #966177
04/04/11 09:45 PM
04/04/11 09:45 PM
scratchnfotraction Offline
yep eddie sells the mopar throttle adaptor and you use the throttle stud from the 2-v carb to hook the cable and throttle pressure valve linkage up
most times you can lengthen the TPV linkage from intake bell crank to the carb 1.5" or so and bend it around and make the 2-v linkage work
this is important to keep the tranz from burning up and to have the shift points set correctly
when you go from the SB to the BB you will need BB TPV linkage for your yr b-body
I dont thin any of the SB stuff will fit or work for the swap
I sugest you locate these parts before swaping in the BB along with the BB tranz
you shift likage should hook up from SB 727 to BB 727 with maybe some adjustments..IIRC
most important is to have the throttle pressurevalve linkage hooked up and adjusted correctly
thats the most important thing on the auto tranz
Re: Edelbrock carb question [Re: scratchnfotraction] #966178
04/04/11 10:00 PM
04/04/11 10:00 PM
USA
USA
Thanks for all the help guys.
Anyone know where to get the BB transmission linkage (TPV?) other than from a parts car?
Re: Edelbrock carb question [Re: JoesMopar] #966179
04/04/11 10:25 PM
04/04/11 10:25 PM
The "parts 4 sale" sections (on here). Right to your mailbox
Re: Edelbrock carb question [Re: RapidRobert] #966180
04/05/11 07:27 AM
04/05/11 07:27 AM
the Bouchillon cable is another option
the lokar cable is an option but not as good as the Bouchillon one
parts wanted add here on the board
parts car
full manual valve body,linkage not needed..thats the way i went with my 88 440 truck...stock linkage for a truck was pricy
good luck
Re: Edelbrock carb question [Re: RapidRobert] #966181
04/05/11 10:56 AM
04/05/11 10:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Since he is using a performer RPM that will not work , NO WELL ...
Re: Edelbrock carb question [Re: JoesMopar] #966182
04/05/11 03:44 PM
04/05/11 03:44 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Here's my 340 with a 1405 600 manuel choke Eddie carb. BTW a manuel choke Eddie is way better for performance than a electric choke model. I would never want one.
This setup(throttle bracket and trans linkage) has been cut on, welded on, modified since the late 70s. It has been used on at least 5 different manifolds over the years. But it give you and idea of what the brackets look like. This one's a driver and I don't worry about cleaning the engine. As long as it don't leak oil, I don't touch it.
It looked the same after running it hard at Bonneville. No oil leaks!
Nitrous trigger equipped.
I don't use a choke cable, although here lately I've been thinking about putting one on...Only because I have driven the car in cold climates, like at the top of Pikes Peak.
I think this is a different manifold in this picture.
These 2 pictures were taken after I drove the crap out of it on the salt in Utah. I disconnected the vacumn advance because I wanted to be sure my motor would be good at hi speed at miles at a time. It lived and going back this year. It went 118 MPH last year not really trying, watch out this year.
Re: Edelbrock carb question [Re: Challenger 1] #966183
04/05/11 04:20 PM
04/05/11 04:20 PM
Cincinnati, Ohio
Cincinnati, Ohio
I tried this RPM manifold, it was a dog compared to a Victor340 which I currently run.
Re: Edelbrock carb question [Re: Challenger 1] #966184
04/05/11 05:05 PM
04/05/11 05:05 PM
what is the link chain for?
throttle stop?
NOS micro pull switch for WOT only?
I need to add something like that for when my boy drives my truck
detune it a bit
Re: Edelbrock carb question [Re: scratchnfotraction] #966185
04/05/11 05:26 PM
04/05/11 05:26 PM
Cincinnati, Ohio
Cincinnati, Ohio
throttle stop?
detune it a bit
NOS switch, don't use it anymore. Yea, shorten the chain and you got yourself a throttle stop, he might never know. lol
Yea it was very cool when you take someone for ride. I'd stand on it and the NOS would come on and they would be amazed that a 340 could run like that. lol I never told some people the truth, they didn't need to know.
I was the NOS king in my neighborhood around 1979 or so. I installed about 10 systems for guys around town.
I had a 87 4x4 ramcharger with a factory 360 and quadrajet carb. I installed 33.5" tires and 4:11 front and back. I put NOS on it and it ran 14.2 at the drag strip in 2 wheel drive in the 1/4 mile. First I'd do a 4 wheel drive burn out, the crowd would go nuts and I was beating some 5.0 mustangs.
Here's a partial picture of it.
Sorry for being OT
