65 belvedere frame #964703
04/02/11 07:47 PM
04/02/11 07:47 PM
saint paul mn.
johnzgarage Offline OP
saint paul mn.
Anyone have a FRAME DIMENSION CHART for a 65 belvedere ??? I think the front frame is out of square. It would be a great help if someone could message me a copy. It might just be why I cant get the hood to fit right........1/2+ gap on LT side ,no gap on Rt side with fender shimmed out at least a 1/2.
Re: 65 belvedere frame [Re: johnzgarage] #964704
04/02/11 09:03 PM
04/02/11 09:03 PM
Andrewh Offline
Andrewh  Offline
hood is more likely the hinges.
you can bend them around pretty good to get the gap straight on both sides.
feets and I tweaked the heck out of his hood to get the gaps on both sides more even.
It isn't physically held up on any part of the car.
Re: 65 belvedere frame [Re: johnzgarage] #964705
04/02/11 10:12 PM
04/02/11 10:12 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Johnz,
PM me your email address and I can send you a PDF later tonight after I scan the FSM page 23-91.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: 65 belvedere frame [Re: johnzgarage] #964706
04/02/11 10:13 PM
04/02/11 10:13 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I had the body measurements for the 65s but somebody LOST THE FRIGGIN CD!!!
I won't mention any names but his initials are Andrewh.
- Stu Harmon
Re: 65 belvedere frame [Re: feets] #964707
04/02/11 10:24 PM
04/02/11 10:24 PM
Andrewh Offline
Andrewh  Offline
you spelled it wrong. and actually I found it.
Re: 65 belvedere frame [Re: Andrewh] #964708
04/02/11 10:51 PM
04/02/11 10:51 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
That is a C Body Subframe chart .
"Long Live Mopars"
Re: 65 belvedere frame [Re: Andrewh] #964709
04/02/11 11:01 PM
04/02/11 11:01 PM
saint paul mn.
saint paul mn.
Hey thank's !!! when I bought the car, it was just a shell and was missing the front of the frame + core support. I welded in the missing parts last winter and I had thought I did a good job . Looks straight and measures out straight, But I never did a over-all check of the frame. Im kinda thinking now it might be in the pass side fender. The fender just doesnt want to mate up right with the door. Im going to swap the fender out on monday and see how things fit.
Re: 65 belvedere frame [Re: johnzgarage] #964710
04/02/11 11:05 PM
04/02/11 11:05 PM
saint paul mn.
saint paul mn.
another. old photo's.. I'll have to take some new one's that show all the parts on....
Re: 65 belvedere frame [Re: johnzgarage] #964711
04/02/11 11:12 PM
04/02/11 11:12 PM
Albany, NY
Albany, NY
I'll try posting it here otherwise you'll end up with the front clip of a C-body.
Re: 65 belvedere frame [Re: 67SATisfaction] #964712
04/02/11 11:14 PM
04/02/11 11:14 PM
Albany, NY
Albany, NY
In the post above, you have to click on 'Attachment'.
It didn't post as an image.
Good luck, -Art
Re: 65 belvedere frame [Re: 67SATisfaction] #964713
04/03/11 01:40 AM
04/03/11 01:40 AM
Andrewh Offline
Andrewh  Offline
lol, sorry. I can't get the software to run, so I can only view the images. I didn't go through the whole manual. Thought it was only for the 65 plymouth b. didn't realize it was the whole 65 service manual.
Re: 65 belvedere frame [Re: Andrewh] #964714
04/03/11 06:50 PM
04/03/11 06:50 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Heh. You spelled B body wrong in your search.
- Stu Harmon
