Hey guys, I have a BB engine question? #964429
04/02/11 03:29 PM
04/02/11 03:29 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
Is there a formula available to determine how big a valve a particular bore can support? Like for instance, could a 4.375 bore handle a 2.4in diameter valve if the head could supply enough air flow. I know some of you engine gurus can point me in the right direction. This engine of course would be a very wild high end comp style engine turning +9000rpm. I'm thinking it would take that type of rpm to move the air. Thanks for the help, its much appreciated!
-Adriel
Adriel Paradise
Substation Design Engineer III
Re: Hey guys, I have a BB engine question? [Re: Adrielp] #964430
04/02/11 03:47 PM
04/02/11 03:47 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i have seen a topic on this on speedtalk.com if you want to do a search there on it.
http://speedtalk.com/forum/viewtopic.php...87b39aef0d16e19
Re: Hey guys, I have a BB engine question? [Re: blownzoom440] #964431
04/02/11 04:07 PM
04/02/11 04:07 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
My worry is what head are you going to try and use?
I'm pretty sure the wedge heads that can fit a 2.4 valve all need a min of a 4.5 bore. Although I could be wrong.
Re: Hey guys, I have a BB engine question? [Re: Diablo] #964432
04/02/11 04:23 PM
04/02/11 04:23 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
BIG rpm .... gotsta' have have big valves OR many of them.
On the opposite end ...I am building a loooow rpm engine with smaller ports and smaaaall valves ... 1.88 and 1.50. But it will never see much-over 4500 or so.
Re: Hey guys, I have a BB engine question? [Re: Diablo] #964433
04/02/11 04:27 PM
04/02/11 04:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was going to run my B1m/c with a 2.4 valve on a
4.440 bore... but I didnt like the shrouding ...
this was going to be a 9000+ rpm engine(514ci)
Re: Hey guys, I have a BB engine question? [Re: blownzoom440] #964434
04/02/11 04:40 PM
04/02/11 04:40 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
Thanks very much! That was a big help. Looks like 2.34in is the magic number.
Adriel Paradise
Re: Hey guys, I have a BB engine question? [Re: MR_P_BODY] #964435
04/02/11 05:35 PM
04/02/11 05:35 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
Morgan says use a valve that is 52-.525 of the bore for all wedge heads and .53-.535 of the bore for canted valve heads so that would be a 2.33in valve for that B1 combo.
This question was more of theoretical thing for my purposes. And lets just say I'm tinkering around with cylinder head design. Thanks for all the help, I pretty much found what I needed and more. These forums are great for the brain sometimes as I'm constantly learning more and more. Thanks again
You guys also gave me another question to ask. I will put this one in the boosted forum though.
Adriel Paradise
