Challenger rear sway-bar option? #964395
04/02/11 02:24 PM
04/02/11 02:24 PM
Pa.
EvilScamp Offline OP
Pa.
70/71 Challenger rear sway-bar was this an option? Rare or common if they were available?
Re: Challenger rear sway-bar option? [Re: EvilScamp] #964396
04/02/11 07:06 PM
04/02/11 07:06 PM
IN
ahy Offline
ahy  Offline
IN
I believe it was installed on the AAR. I would say rare. Firm Feel reproduces a factory style rear bar.
Re: Challenger rear sway-bar option? [Re: EvilScamp] #964397
04/02/11 07:17 PM
04/02/11 07:17 PM
Up in the North and Far Away
AutoEngineer Offline
Also installed on the T/A Challenger and later as an options for other Challengers. So not a common option on the 70/71's
Re: Challenger rear sway-bar option? [Re: AutoEngineer] #964398
04/02/11 09:49 PM
04/02/11 09:49 PM
Pa.
Pa.
Thanks for the replies guys, i asked because i recently ran across one and i had never seen one before.
The brackets are bolted to the frame and not welded so i'm trying to figure out if it's original or an aftermarket, it looks like it has been on the car for at least 20 years if not alot longer.
Re: Challenger rear sway-bar option? [Re: EvilScamp] #964399
04/02/11 10:43 PM
04/02/11 10:43 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Sway bar brackets bolt to the frame, four bolts per side the bracket forms a "C" around the frame rail... They aren't as rare as this thread makes them seem... After a certain production date all cars with rally suspension (all 340's & all R/T's) were supposed to get the rear bar.. There should also be a plate sandwiched between the axle & the spring that the links attach to...
Re: Challenger rear sway-bar option? [Re: 1_WILD_RT] #964400
04/02/11 11:47 PM
04/02/11 11:47 PM
kansas city, mo
rave_12000 Offline
rave_12000  Offline
kansas city, mo
mounting plates are getting more difficult to find. actual sway bar is easy to find.
Re: Challenger rear sway-bar option? [Re: EvilScamp] #964401
04/03/11 10:32 AM
04/03/11 10:32 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I don't know how rare they actually are, but my 70 340 Challenger (A66)came with one.
Re: Challenger rear sway-bar option? [Re: rave_12000] #964402
04/03/11 12:11 PM
04/03/11 12:11 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Yep. I've got a bar, let the plates get away.
