carb and cam upgrade... I need thoughts and opinions. #964329
04/02/11 12:10 PM
04/02/11 12:10 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
Looking to upgrade my 68 Satellite for a more potent carb and cam setup.
Current set-up:
440 bored .30
Eddy 84cc heads w rpm performer intake
600 cfm carb w/ mild comp cam
TTI headers with x pipe
727
3.55 tru trac with 489 casing
torque boxes and frame connectors
looking at MP 509 cam and 750 to 850 carter carb..
trying to get more out of her at the track but still have street manners...
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: carb and cam upgrade... I need thoughts and opinions. [Re: 68 Sat] #964330
04/02/11 12:18 PM
04/02/11 12:18 PM
750 3310 basic vac secondary. No opinion on the cam (not a cam guy). What scr? Measured CR?
Re: carb and cam upgrade... I need thoughts and opinions. [Re: RapidRobert] #964331
04/02/11 12:24 PM
04/02/11 12:24 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I agree with the above carb choice . As far as cam, the 509 is a great bracket race cam, old school, and can make great #'s but you give up a little in terms of drivability for a STREET car.
The newer high lift, less duration ( because of aggressive cam ramps)
Make for better street manners while still making good top end numbers.
Comp and Lunati have good offerings
Re: carb and cam upgrade... I need thoughts and opinions. [Re: Pacnorthcuda] #964332
04/02/11 12:36 PM
04/02/11 12:36 PM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hello I like the 509 cam ! They make it two ways one is more for racing and the other one is more for the street,I put them in all of my big block Mopar 440 and some 383.I like the Holley 850 DP or six pack set ups ,most all of my iron heads have 214 intake valves and 181 exhaust valves and I run 3" exhaust pipes all the way back with a crossover pipe.also stock HP manifolds.
Re: carb and cam upgrade... I need thoughts and opinions. [Re: 68 Sat] #964333
04/02/11 01:34 PM
04/02/11 01:34 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Current set-up:
440 bored .30
727
Please provide:
Current cam specs.
CR
Converter info
Tire used at the track
weight - car w/driver
current et and mph
Re: carb and cam upgrade... I need thoughts and opinions. [Re: BSB67] #964334
04/02/11 05:59 PM
04/02/11 05:59 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
cam specs are as follows
Big Chrysler 1800-5500 duration224/224 lift.470/.470
What is CR?
The torque converter I believe is 0 meaning there is no stall.
tires at the rear are 295/55/15 MT street drags
I can tell you my weight is 230 but not the cars total weight....
I ran mid 14s at 99 mph with a 2.97 open rear and no tires last year, so I am hoping for a bit more..
Re: carb and cam upgrade... I need thoughts and opinions. [Re: 68 Sat] #964335
04/02/11 06:34 PM
04/02/11 06:34 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
If you have a stock torque converter, I wouldn't go any bigger on the cam than what you have. If it were me, i would put in about a 3500 stall and a 750 DP and worry about a cam later. Do you have a Performer or Performer RPM? If just a regular Performer, A swap to an RPM or a Holley Street Dominator would be an improvement. IMO , the biggest gains will come from a carb and coverter change.
Re: carb and cam upgrade... I need thoughts and opinions. [Re: Pacnorthcuda] #964336
04/02/11 06:41 PM
04/02/11 06:41 PM
Connecticut, USA
sixty7gtx Offline
sixty7gtx  Offline
Connecticut, USA
I think the Lunati 513 lift with a edellbrook 600 is a nice set up for street or strip!
1967 Plymouth GTX,
1968 HEMI, 4 Spd. Super Bee,
2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
