Re: Only a VIN...
[Re: MoparJunkie]
#964197
04/02/11 09:38 AM
04/02/11 09:38 AM
Posts: 74,977 U.S.S.A.
JohnRR
U.S.S.A.
How much can a person tell about a car that only has VIN stampings? Is there a source as to tell what options that VIN had without a build sheet? I guess what I'm asking is there any type of database that could contain this info?????
You can tell what model it is, what engine it has , where it was built and a time frame for when in the model year it was built . Unless someone happens to have a photo of the fendertag, broadcast sheet or dealer invoice you are SOL in finding out anything else. You aren't dealing with Ponitacs here .
Re: Only a VIN...
[Re: MoparJunkie]
#964198
04/02/11 10:55 AM
04/02/11 10:55 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
It depends...
If it's a pre 68, Chrysler Historical MAY have the IBM card for the car. If that was available, then yes, there would be a source to tell how the car was equipped.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
