Re: Surface Primer?
[Re: racerx]
#963840
04/07/11 11:58 PM
04/07/11 11:58 PM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
I just use a paint mixing stick(a wood one)So block it with 180,then reprime it,and then block it again this time with 320-400.It takes along time but its the right way to do it.If you do the final sanding with wetsanding paper get a rubber squeegee to dry it off between sanding.That way you can see quickly if you missed anything.
Re: Surface Primer?
[Re: AdamR]
#963843
04/08/11 08:43 AM
04/08/11 08:43 AM
Challenger 1
Cincinnati, Ohio
Sand and sand again, I go 180. 220, 320, 600 wet, 800 wet.
Then paint and clear, back to sanding 1500 wet, 3000 wet.
Yup, you will get some toned arms by the time your done.
AdamR, are you the same Adam that helped me paint my car in 2005? This Adam had a body work website.
Re: Surface Primer?
[Re: Challenger 1]
#963844
04/08/11 08:55 AM
04/08/11 08:55 AM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
Possibly, I had a web site up for a while. Im one of those odd people who love blocking, LOL. I did a lot of blocking on a few members cars. I did Big Inch Motors Barracuda and 340Swings Dart. Quote:
