Re: Surface Primer? [Re: racerx] #963838
04/07/11 11:19 PM
04/07/11 11:19 PM
IN
ahy Offline
ahy  Offline
IN
The 180 (or 150) will smooth and level it. Its best to sand the first coat thoroughly with aggressive grit, re-prime and then hit it with 320/400. If you aren't re-priming the work up to 220/320/400... but by then you will be through the first primer.
Re: Surface Primer? [Re: ahy] #963839
04/07/11 11:41 PM
04/07/11 11:41 PM
Mo.
racerx Online work OP
racerx  Online Work OP
Mo.
I see Thaxx's guys
Re: Surface Primer? [Re: racerx] #963840
04/07/11 11:58 PM
04/07/11 11:58 PM
Amherst,NY
challengermike Offline
Amherst,NY
I just use a paint mixing stick(a wood one)So block it with 180,then reprime it,and then block it again this time with 320-400.It takes along time but its the right way to do it.If you do the final sanding with wetsanding paper get a rubber squeegee to dry it off between sanding.That way you can see quickly if you missed anything.
Re: Surface Primer? [Re: challengermike] #963841
04/08/11 08:22 AM
04/08/11 08:22 AM
Mo.
Mo.
Man....u guys r making what to This body work is to tedious.......Thaxx's 4 the help everyone
Re: Surface Primer? [Re: racerx] #963842
04/08/11 08:35 AM
04/08/11 08:35 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Sand and sand again, I go 180. 220, 320, 600 wet, 800 wet.
Then paint and clear, back to sanding 1500 wet, 3000 wet.
Re: Surface Primer? [Re: AdamR] #963843
04/08/11 08:43 AM
04/08/11 08:43 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yup, you will get some toned arms by the time your done.
AdamR, are you the same Adam that helped me paint my car in 2005? This Adam had a body work website.
Re: Surface Primer? [Re: Challenger 1] #963844
04/08/11 08:55 AM
04/08/11 08:55 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Possibly, I had a web site up for a while. Im one of those odd people who love blocking, LOL.
I did a lot of blocking on a few members cars. I did Big Inch Motors Barracuda and 340Swings Dart.
Re: Surface Primer? [Re: AdamR] #963845
04/08/11 09:06 AM
04/08/11 09:06 AM
Cincinnati, Ohio
Cincinnati, Ohio
Car looks great!
Thanks if it were you, you helped me a ton. Yes I like blocking too, something about it. Get in a zone and sweat your azz off, it's great!
