exhaust valve rotaters #963777
04/01/11 03:18 PM
04/01/11 03:18 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
what is their purpose? do i need them? they are on #302 heads on a near stock 318.
Re: exhaust valve rotaters [Re: 65rbdodge] #963778
04/01/11 03:43 PM
04/01/11 03:43 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
They use a very short valve spring and any added lift would be very marginal before coil bind. Get rid of them and use regular retainers and regular length springs if upgrading to bigger cam..
They are to help prevent valve and valve seat burnouts by keeping the valve in constant rotation in the guide allowing a different seating position each time the valve closes.
Re: exhaust valve rotaters [Re: MoparforLife] #963779
04/01/11 03:48 PM
04/01/11 03:48 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Mostly used in trucks and industrial motors, as said, they help in preventing buildup on the exhaust valve face. They are physically heavier than normal retainers so they are usually tossed in a performance rebuild. On a stock motor, they hurt nothing.
Re: exhaust valve rotaters [Re: pishta] #963780
04/01/11 09:04 PM
04/01/11 09:04 PM
scratchnfotraction Offline
ditch thoise and use a diff spring with 8 more stock intake retainers
PM if you need 8 more retainers,I have a bunch you can have
Re: exhaust valve rotaters [Re: MoparforLife] #963781
04/01/11 10:55 PM
04/01/11 10:55 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Well said... Most readers will say throw it away not knowing that they do work and have reason to be there on certain applications.
Re: exhaust valve rotaters [Re: NITROUSN] #963782
04/01/11 11:14 PM
04/01/11 11:14 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
They are a VERY valuable piece on a grunt motor .. like an RV, towing or truck-type motor. Very TRUE ... they are not a high-rpm HP part at all.
I have no OEM cost-diff ... but I would wager that those retainers cost Ma Mopar 4 TIMES what a standard piece costs.
DON'T throw-em-out ...save 'em furr me !
Re: exhaust valve rotaters [Re: dOc !] #963783
04/02/11 06:04 PM
04/02/11 06:04 PM
Florida STAYcation
Florida STAYcation
AFTER thinking about this post I had to go out to the barn and pull a rotator off a set of heads.....
DAMN that thing is trick ... there is some kind of "bearing" in there ....roller or ball.
Re: exhaust valve rotaters [Re: dOc !] #963784
04/02/11 07:56 PM
04/02/11 07:56 PM
Upper Midwest
Upper Midwest
Here in picture form. Not all were on truck engines many were on cars too. Did you notice how short the springs use with them are.
Re: exhaust valve rotaters [Re: MoparforLife] #963785
04/02/11 09:49 PM
04/02/11 09:49 PM
Florida STAYcation
Florida STAYcation
It appears to me that the keepers go deeper into the retainer itself ... diff height springs ? ... The one I have here is about 2.200.
Re: exhaust valve rotaters [Re: dOc !] #963786
04/02/11 09:53 PM
04/02/11 09:53 PM
Upper Midwest
Upper Midwest
Very much different height springs. If your's aren't someone has really compressed them to get them in. I can get some virgin springs tomorrow set up and picture.
Re: exhaust valve rotaters [Re: MoparforLife] #963787
04/02/11 10:02 PM
04/02/11 10:02 PM
Florida STAYcation
Florida STAYcation
I went out and found a well-used) HP spring(with the dampner) .. it appears to be the same height. definately wider though.
Re: exhaust valve rotaters [Re: dOc !] #963788
04/02/11 10:08 PM
04/02/11 10:08 PM
Upper Midwest
Upper Midwest
Well I also went out an looked and mine went out last fall clean up. I am sure that the ones I have had off over the tears were shorter to compensate for the thick retainer. I may mistaken as it has been a while and I won't argue with you. Life is too short. I do know that when this came in the shops here the whole thing was swapped out. I have a dam good memory but it is getting shorter all the time and it never was too long. I would still use spring compatible with the cam.
Re: exhaust valve rotaters [Re: dOc !] #963789
04/02/11 11:04 PM
04/02/11 11:04 PM
N
NITROUSN Offline
NITROUSN  Offline
N
This is where the problem comes in. Intake springs will fit just fine but look out. You have to be very carefull and loaded spring rates should be checked.
Years back we had a shop do a valve job on a 79 318 power wagon. Within 60 miles it was towed back with a dropped exhaust valve. The heads were pulled and sent to a rebuilder for a un-biased opinion. Result was intake springs accidently installed on exhaust valves with rotators. The seat pressures were like doubled if not more as I remember.
Not sure on the physical heights between them.
Re: exhaust valve rotaters [Re: MoparforLife] #963790
04/02/11 11:26 PM
04/02/11 11:26 PM
Florida STAYcation
Florida STAYcation
...and I should make it very plain .. the springs I have here are certainly used. And those rotating retainers ARE much thicker .. but again ...it APPEARS that the keepers sit waaaay lower into the retainer itself.
Now I can NOT compare a "std" retainer on the exh valve because the stem size on the 1.50 exh valve is so much larger.
A side note ....I put the rotator on the HP spring ...and it fits fine.
Re: exhaust valve rotaters [Re: NITROUSN] #963791
04/02/11 11:32 PM
04/02/11 11:32 PM
Florida STAYcation
Florida STAYcation
So it BROKE the stem of the valve ? ...
I am going to have some EXTENSIVE work(DEporting and swirl work) done to these heads and I will be sure to have the cyl head guy check all open and closed pressures.
Re: exhaust valve rotaters [Re: dOc !] #963792
04/03/11 07:52 AM
04/03/11 07:52 AM
Upper Midwest
Upper Midwest
Something is not right there, doc. We ave always used standard retainers on the valve when changing springs. Here is a picture of a result of using rotators with a small 485 lift cam. As there had been new valve installed on the job the good ones were reused on nondamaged heads. Have used standard retainers and compatible springs on many since.
Re: exhaust valve rotaters [Re: MoparforLife] #963793
04/03/11 02:13 PM
04/03/11 02:13 PM
a stock exhast spring with rotator is shorter than the stock intake spring
I had a machine shop mix one intake spring up on a valve job
couple days later it snaped the end off the valve,locks and tip of valve still in the rotator when I tore it back down
busted a piston,wiped the cyl walls out,suck piston into almost all other cyls
I told and showed them the 8 shorter springs and the bigger intake springs when I droped them off for the valve job
I will never use any more rotators when a rebuild or spring upgrade is at hand on mine
Re: exhaust valve rotaters [Re: MoparforLife] #963794
04/04/11 04:05 AM
04/04/11 04:05 AM
Florida STAYcation
Florida STAYcation
Don ....NOT RIGHT ? ... I am a newbie at this. NEVER tried any type of R&D on these type heads ever before. I am learning as I am going-along.
That damage ... ....what are you suggesting that the rotators did to cause that ?
Re: exhaust valve rotaters [Re: scratchnfotraction] #963795
04/04/11 04:18 AM
04/04/11 04:18 AM
Florida STAYcation
Florida STAYcation
Mike ....I have to ask you the same Q .... wassssupy ? ...
These are feeble low-lift cams... no chance of over-taxing the springs or coil-bind....
I have both of the spring in front of me ... the 413 exh VS(really a feeble looking piece) ...and then the HP spring with the dampner. Same height, same ID .... the rotators sits FINE in the HP spring .....
I like the idea of using the HP spring....to have more pressure on the cam to insure good contact and-TO INSURE good lifter movement ...PLUS with the inner dampner .. it prevent excess oil getting into the valve guides.
Re: exhaust valve rotaters [Re: dOc !] #963796
04/04/11 07:05 AM
04/04/11 07:05 AM
Doc,I can only speak of the ones I have messed with and they are on SB
I have never checked a set on a BB
