Re: What CARB/INTAKE Combo Would you use?!
[Re: midnite360]
#963535
04/01/11 09:38 AM
04/01/11 09:38 AM
Posts: 15,487 Florida
scratchnfotraction
IMHO LD340 with a 750cfm holley heres a LD4B with 600 eddie on a 318
[Re: MN-ScatPack]
#963537
04/01/11 09:53 AM
04/01/11 09:53 AM
Posts: 3,920 n.e. pa.
65rbdodge
n.e. pa.
Edelbrock Performer RPM & 750 Holley.
X2
[Re: midnite360]
#963540
04/01/11 10:04 AM
04/01/11 10:04 AM
Posts: 646 VA.
mosweethemi
VA.
Hello We have a 1974 Dodge Dart Swinger with a 1970 340 std bore ,stock 340 pistons,J heads 202 ,160 valves with a 484 cam and the intake is from Mopar Perfromance and looks like a M1 , It is a SB intake and we have a 650 Holley SB,DP and it works fine. 727 trans. 3000 stall. 323 rear, stock exhaust manifolds with 2 1/2 with 40s flowmaster muffers.The intake did not have any heater hose hook ups or a place for a manuel temp unit ,we put them in the intake. also we have a 4"x14" K&N air filter on it. [IMG]http://i1100.photobucket.com/albums/ The K&N 4"X14" AIR FILTER WAS ADDED AFTER PICTURES WERE TOOK,
[Re: scratchnfotraction]
#963542
04/01/11 10:41 AM
04/01/11 10:41 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
IMHO
I second this. My duster ran consistent 11.40's with this intake
[Re: midnite360]
#963543
04/01/11 11:04 AM
04/01/11 11:04 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
""360LA 360-375HP. 9.75/1 Comp, Headman A body Headers, 2500RPM Stall converter. Streat/strip 727 Built by Hughes Performance.""
What gears and tire size?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#963544
04/01/11 11:47 AM
04/01/11 11:47 AM
Posts: 947 Goodyear Arizona
midnite360
Goodyear Arizona
3.55's with a 255/60/15 on the back Believe its a 27in tall tire...
Thanks for the Suggestions You guys rock and are helping to make a very tough decision!
[Re: midnite360]
#963545
04/01/11 12:01 PM
04/01/11 12:01 PM
YO7_A66
Indiana
""3.55's with a 255/60/15 on the back Believe its a 27in tall tire.""
Mainly due to the 2500 stall, I would suggest the 650/750 vacuum secondary carbs. I would also suggest to choose one with adjustable circuits (IAB's/HSAB's and IFR's) This makes future engine modifications easier to tune.
Intake: RPM/RPM Airgap.
[Re: midnite360]
#963547
04/01/11 12:33 PM
04/01/11 12:33 PM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
What carp intake combo would you use?
This question sounds kind of fishy to me.....
Sorry, couldn't resist.
Edelbrock RPM Airgap and 650 double pumper Holley.
[Re: midnite360]
#963548
04/01/11 01:16 PM
04/01/11 01:16 PM
Posts: 18,160 Mass
DAYCLONA
Mass
[Re: dustergirl340]
#963550
04/01/11 08:53 PM
04/01/11 08:53 PM
Posts: 1,460 oklahoma
forphorty
oklahoma
LD340 or an Airgap with a 650DP Holley and I'd change the converter to a PTC 3,500. But that's just me.
