What CARB/INTAKE Combo Would you use?! #963534
04/01/11 09:22 AM
04/01/11 09:22 AM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
Ok so I had a post about weiand intakes but what would you put on my eninge. 360LA 360-375HP. 9.75/1 Comp, Headman A body Headers, 2500RPM Stall converter. Streat/strip 727 Built by Hughes Performance. Engine is getting revved to 6000RPM What carp intake combo would you use?
Re: What CARB/INTAKE Combo Would you use?! [Re: midnite360] #963535
04/01/11 09:38 AM
04/01/11 09:38 AM
scratchnfotraction Offline
IMHO
LD340 with a 750cfm holley
heres a LD4B with 600 eddie on a 318
Re: What CARB/INTAKE Combo Would you use?! [Re: midnite360] #963536
04/01/11 09:42 AM
04/01/11 09:42 AM
Twin Cities, MN
MN-ScatPack Offline
MN-ScatPack  Offline
Twin Cities, MN
Edelbrock Performer RPM & 750 Holley.
Re: What CARB/INTAKE Combo Would you use?! [Re: MN-ScatPack] #963537
04/01/11 09:53 AM
04/01/11 09:53 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
X2
Re: What CARB/INTAKE Combo Would you use?! [Re: midnite360] #963538
04/01/11 09:58 AM
04/01/11 09:58 AM
Central NC
gch Offline
gch  Offline
Central NC
Hard to go wrong with a performer rpm intake and a holley 750 vacuum secondary for street use.
You will get 10 different answers to your question.
Depending on your rear gears and strip usage a double pumper may e.t. slightly better.
Re: What CARB/INTAKE Combo Would you use?! [Re: midnite360] #963539
04/01/11 10:03 AM
04/01/11 10:03 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
if you are going to spin it to 6k I'd use an RPM air-gap and a 750DP of course.
Coming soon!!!!
Re: What CARB/INTAKE Combo Would you use?! [Re: midnite360] #963540
04/01/11 10:04 AM
04/01/11 10:04 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hello We have a 1974 Dodge Dart Swinger with a 1970 340 std bore ,stock 340 pistons,J heads 202 ,160 valves with a 484 cam and the intake is from Mopar Perfromance and looks like a M1 , It is a SB intake and we have a 650 Holley SB,DP and it works fine. 727 trans. 3000 stall. 323 rear, stock exhaust manifolds with 2 1/2 with 40s flowmaster muffers.The intake did not have any heater hose hook ups or a place for a manuel temp unit ,we put them in the intake. also we have a 4"x14" K&N air filter on it. [IMG]http://i1100.photobucket.com/albums/ The K&N 4"X14" AIR FILTER WAS ADDED AFTER PICTURES WERE TOOK,
Re: What CARB/INTAKE Combo Would you use?! [Re: mosweethemi] #963541
04/01/11 10:40 AM
04/01/11 10:40 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I'd run an LD340 or an RPM with a 650dp 4777 with that mild converter. Even a "Street" Dom. intake will do good.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: What CARB/INTAKE Combo Would you use?! [Re: scratchnfotraction] #963542
04/01/11 10:41 AM
04/01/11 10:41 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
IMHO
I second this. My duster ran consistent 11.40's with this intake
Re: What CARB/INTAKE Combo Would you use?! [Re: midnite360] #963543
04/01/11 11:04 AM
04/01/11 11:04 AM
Indiana
Y
YO7_A66 Online content
YO7_A66  Online Content
Y
Indiana
""360LA 360-375HP. 9.75/1 Comp, Headman A body Headers, 2500RPM Stall converter. Streat/strip 727 Built by Hughes Performance.""
What gears and tire size?
Re: What CARB/INTAKE Combo Would you use?! [Re: YO7_A66] #963544
04/01/11 11:47 AM
04/01/11 11:47 AM
Goodyear Arizona
Goodyear Arizona
3.55's with a 255/60/15 on the back Believe its a 27in tall tire...
Thanks for the Suggestions You guys rock and are helping to make a very tough decision!
Re: What CARB/INTAKE Combo Would you use?! [Re: midnite360] #963545
04/01/11 12:01 PM
04/01/11 12:01 PM
Indiana
Y
Y
Indiana
""3.55's with a 255/60/15 on the back Believe its a 27in tall tire.""
Mainly due to the 2500 stall, I would suggest the 650/750 vacuum secondary carbs. I would also suggest to choose one with adjustable circuits (IAB's/HSAB's and IFR's) This makes future engine modifications easier to tune.
Intake: RPM/RPM Airgap.
Re: What CARB/INTAKE Combo Would you use?! [Re: YO7_A66] #963546
04/01/11 12:22 PM
04/01/11 12:22 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
LD340 or an Airgap with a 650DP Holley and I'd change the converter to a PTC 3,500. But that's just me.
Re: What CARB/INTAKE Combo Would you use?! [Re: midnite360] #963547
04/01/11 12:33 PM
04/01/11 12:33 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
This question sounds kind of fishy to me.....
Sorry, couldn't resist.
Edelbrock RPM Airgap and 650 double pumper Holley.
Re: What CARB/INTAKE Combo Would you use?! [Re: midnite360] #963548
04/01/11 01:16 PM
04/01/11 01:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
6 pak
Re: What CARB/INTAKE Combo Would you use?! [Re: DAYCLONA] #963549
04/01/11 03:50 PM
04/01/11 03:50 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
6 pak
That too
Re: What CARB/INTAKE Combo Would you use?! [Re: dustergirl340] #963550
04/01/11 08:53 PM
04/01/11 08:53 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: What CARB/INTAKE Combo Would you use?! [Re: midnite360] #963551
04/02/11 03:23 AM
04/02/11 03:23 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
It's hard to beat the Performer RPM air-gap intake for that setup. The 750cfm carb is good.
I just looked at summit racing and they have a house brand 750, that looks like a holley knock off on sale for $251. Anyone use one of these carbs?
http://www.summitracing.com/parts/SUM-M08750VS/?rtype=10
Re: What CARB/INTAKE Combo Would you use?! [Re: midnite360] #963552
04/16/11 04:52 AM
04/16/11 04:52 AM
Goodyear Arizona
Goodyear Arizona
Well wen't with a Eddy Rpm-AirGap.....
Anybody know about demon carbs? Would you recommend one?
Re: What CARB/INTAKE Combo Would you use?! [Re: midnite360] #963553
04/16/11 10:10 AM
04/16/11 10:10 AM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
what are the cam specs?
