Help needed. My 4 speed conversion is underway. #963436
03/31/11 11:34 PM
03/31/11 11:34 PM
Twin Cities, MN
MN-ScatPack Offline OP
Twin Cities, MN
So I have a friend coming over to weld in my 4 speed hump and I need to know if there is more things that need welding for this conversion. I have the ball stud bracket on order, but is there anything else I need to have welded to convert this challenger from and auto to a manual?
Re: Help needed. My 4 speed conversion is underway. [Re: MN-ScatPack] #963437
03/31/11 11:47 PM
03/31/11 11:47 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Frame bracket and floor tunnel are the only pieces that have to be welded. The 2 stud bracket through the cowl was spot welded from the factory. This eased assembly, but not required.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Help needed. My 4 speed conversion is underway. [Re: MN-ScatPack] #963438
03/31/11 11:48 PM
03/31/11 11:48 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
That's one 4 speed conversion I haven't done, but I think the ball stud mount and the hump are the only parts that require welding. Have fun and good luck.
Mike
Re: Help needed. My 4 speed conversion is underway. [Re: 1E2C] #963439
04/01/11 12:49 AM
04/01/11 12:49 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
installing a console, you'll need console brackets welded also
Re: Help needed. My 4 speed conversion is underway. [Re: DAYCLONA] #963440
04/01/11 09:46 AM
04/01/11 09:46 AM
Twin Cities, MN
Twin Cities, MN
Thanks for the replies. Dayclona, is it the same brackets that the auto's use?
Re: Help needed. My 4 speed conversion is underway. [Re: MN-ScatPack] #963441
04/01/11 09:57 AM
04/01/11 09:57 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No
Re: Help needed. My 4 speed conversion is underway. [Re: Challenger 1] #963442
04/01/11 10:06 AM
04/01/11 10:06 AM
Twin Cities, MN
Twin Cities, MN
No
DANG!
Re: Help needed. My 4 speed conversion is underway. [Re: MN-ScatPack] #963443
04/01/11 10:25 AM
04/01/11 10:25 AM
Cincinnati, Ohio
Cincinnati, Ohio
I'm hoping to do a conversion too, one of these days. I have everything except the bracket that mounts on the frame rail.
Good luck with your conversion. I saved this from this site, maybe it'll help you if you don't already have it.
Re: Help needed. My 4 speed conversion is underway. [Re: Challenger 1] #963444
04/01/11 01:47 PM
04/01/11 01:47 PM
Twin Cities, MN
Twin Cities, MN
Gary -
Do you have a larger pic of this?
Re: Help needed. My 4 speed conversion is underway. [Re: MN-ScatPack] #963445
04/01/11 01:56 PM
04/01/11 01:56 PM
Cincinnati, Ohio
Cincinnati, Ohio
No, that's all there was, not my picture. I know what your thinking. side to side will be easy to fiqure once you get it in place.
Re: Help needed. My 4 speed conversion is underway. [Re: Challenger 1] #963446
04/01/11 04:41 PM
04/01/11 04:41 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Scott,
I assume you are converting an e-body? I believe the hump will only "fit" the contours of the floor pan in one location. Once you find the spot, trace a line around the outside of the hump and cut the floor about an inch inside the line. Watch out for the stuff below when you are cutting.
Re: Help needed. My 4 speed conversion is underway. [Re: Tom_440] #963447
04/02/11 12:22 AM
04/02/11 12:22 AM
Twin Cities, MN
Twin Cities, MN
Thanks Gary.
Tom, yes a Challenger and I will check it out this weekend. I still have to get rid of the slapstick stuff to set the 4 speed hump in place.
