Transmission Adjustment Question #963431
03/31/11 11:34 PM
03/31/11 11:34 PM
Iowa
Hey19 Offline OP
Hey19  Offline OP
Iowa
I had a 727 rebuilt. I have the kick down linkage correct and adjusted correctly. The transmission won't kick down when you floor it. It also seems to shift up pretty rapidly when you just pull away from a stop. Other than that it works fine. Also if I adjust the kick down linkage way out some times it will kick down when floored but it feels like it is pulling down fighting itself slightly before it does shift. Is this a band out of adjustment? The guy that rebuilt it isn't around anymore.
Re: Transmission Adjustment Question [Re: Hey19] #963432
03/31/11 11:38 PM
03/31/11 11:38 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
DO YOU have access to TWO pressure gauges?
Re: Transmission Adjustment Question [Re: dOc !] #963433
03/31/11 11:45 PM
03/31/11 11:45 PM
Iowa
Hey19 Offline OP
Hey19  Offline OP
Iowa
Yes I do.
Re: Transmission Adjustment Question [Re: Hey19] #963434
03/31/11 11:54 PM
03/31/11 11:54 PM
Is the slotted rod pulled all the way forward at idle and how far does that put the TP lever (on the trans) from having to move b 4 it hits some tension inside the trans and at WOT how much further can the throttle pressure (AKA kickdown) lever be moved rearward if you unhooked it. Trying to get an idea of what your lever position baseline is right now
Re: Transmission Adjustment Question [Re: RapidRobert] #963435
04/01/11 12:01 AM
04/01/11 12:01 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
RR has some good adjustment tips.
The EZiest thing to do now is to TIE BACK the KD lever and see what it does.
