Dumb electrical question #962946
03/31/11 09:39 AM
03/31/11 09:39 AM
We don't make mistakes...
67500vert Offline OP
What's a good place to tap into for a "hot when on" power source for an electric fan?
67 Coronet 500 Convertible Nemo me impune lacessit
Re: Dumb electrical question [Re: 67500vert] #962947
03/31/11 09:51 AM
03/31/11 09:51 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
typically i use the outlet in my living room if i'm watching TV. . come on,you know that was funny! anyway, i would say the switched side of the starter relay if the fan has a fuse.
Re: Dumb electrical question [Re: 67500vert] #962948
03/31/11 09:52 AM
03/31/11 09:52 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I used the bateery side of the ballast for my fuel pump.
Coming soon!!!!
Re: Dumb electrical question [Re: mikemee1331] #962949
03/31/11 09:54 AM
03/31/11 09:54 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
in the engine bay- dark blue wire that feeds the ing/voltage reg.( not from the coil side as it is a lower voltage via the resistor! )
use the power from there to turn on a relay that is powered from the battery and fuse.
Re: Dumb electrical question [Re: mikemee1331] #962950
03/31/11 02:03 PM
03/31/11 02:03 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
It IS funny. Too many serious guys on this forum sometimes. Take a joke, people!
Re: Dumb electrical question [Re: Kern Dog] #962951
03/31/11 04:37 PM
03/31/11 04:37 PM
Yep...I had that comin' to me.
Re: Dumb electrical question [Re: 67500vert] #962952
03/31/11 07:51 PM
03/31/11 07:51 PM
As one of the too serious members here I would suggest feeding it right off of the alt w a relay. This keeps tha amperage out of the bulkhead and allows the ammeter to read correct. Want a FL at the alt output stud 2 gauge sizes smaller than that line size.
Re: Dumb electrical question [Re: RapidRobert] #962953
04/01/11 06:33 PM
04/01/11 06:33 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i would disagree with that statement! i've seen your sense of humor.
Re: Dumb electrical question [Re: RapidRobert] #962954
04/02/11 01:45 PM
04/02/11 01:45 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Running a 30-40 amp circuit off of a 14 ga. wire is a bad idea. Use an ice cube relay like said above. You will need a 12V source that turns on with the key to activate the relay. This would be an acceptable use of the blue wire going to the ballast. For the main power feed to the fan run a 10 ga. wire from the main post on the starter solenoid, alternator, or positive battery post. Also employ a fusible link between the main power source and the relay. It would not be a bad idea to put a blade type fuse holder in line with the switch that activates the relay.
