Dumb electrical question
#962946
03/31/11 09:39 AM
03/31/11 09:39 AM
Posts: 575 We don't make mistakes...
67500vert
What's a good place to tap into for a "hot when on" power source for an electric fan?
67 Coronet 500 Convertible
Nemo me impune lacessit
Re: Dumb electrical question
[Re: mikemee1331]
#962950
03/31/11 02:03 PM
03/31/11 02:03 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
typically i use the outlet in my living room if i'm watching TV. . come on,you know that was funny!
It IS funny. Too many serious guys on this forum sometimes. Take a joke, people!
[Re: 67500vert]
#962952
03/31/11 07:51 PM
03/31/11 07:51 PM
RapidRobert
As one of the too serious members here I would suggest feeding it right off of the alt w a relay. This keeps tha amperage out of the bulkhead and allows the ammeter to read correct. Want a FL at the alt output stud 2 gauge sizes smaller than that line size.
[Re: RapidRobert]
#962953
04/01/11 06:33 PM
04/01/11 06:33 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
i would disagree with that statement! i've seen your sense of humor.
[Re: RapidRobert]
#962954
04/02/11 01:45 PM
04/02/11 01:45 PM
Posts: 9,096 Rogue River, OR
Jeremiah
Rogue River, OR
Running a 30-40 amp circuit off of a 14 ga. wire is a bad idea. Use an ice cube relay like said above. You will need a 12V source that turns on with the key to activate the relay. This would be an acceptable use of the blue wire going to the ballast. For the main power feed to the fan run a 10 ga. wire from the main post on the starter solenoid, alternator, or positive battery post. Also employ a fusible link between the main power source and the relay. It would not be a bad idea to put a blade type fuse holder in line with the switch that activates the relay.
