Re: Converter or Cam?
[Re: 68GTS383]
#962850
03/31/11 07:49 AM
03/31/11 07:49 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
If you swap out to a larger cam in your 360, then you will probably need a larger convertor to match it. If you swap out the 25/2800 converter for a 3500rpm unit, your engine will feel like it has more power. You will get more seat of the pants performance from the converter swap than you will a cam swap in your application. Note: When I was running the Comp 270H cam in my 340, I swapped out my stock converter (apx 2500) to this TA 10" unit, and the seat of the pants difference was a huge difference and allot more fun to drive.
I have run my TA Tight 10" for six years on my 340. The first three years was with 3:55 gears and a 26" tire. The last 3 years I have run with 3:91 gears and 27" tires. I added a tranny cooler with the converter swap and I have never had any issues with heat or too much converter on the street. Looking back, I now wished that I would have gone with a tight 9.5" 38-4000 unit.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Mr.Yuck]
#962855
03/31/11 05:38 PM
03/31/11 05:38 PM
Posts: 2,177 ill
dennismopar73
ill
gears / cams/ converter? we all have that issue, haha lol happy medium.. , gears , get the gears,
[Re: moturbopar]
#962857
03/31/11 08:04 PM
03/31/11 08:04 PM
Posts: 2,177 ill
dennismopar73
ill
i have run 10" tci which worked ok in street car but soon as i put it on the strip, it got fatality wounded, then got a ger 10" which worked real well for me ,it was a 3500, then i really moved up to a fairbanks 10" 3500, worked alright my nephew has a 70 challenger, witha 360 tunnel ram with 410 gear, and a stock converter, and a purple shaft 282 cam , he 60ft a 1.69 at monster mopar ran 13,50 stock converter so much for high dollar converts sometimes, jmo
[Re: moturbopar]
#962859
03/31/11 08:42 PM
03/31/11 08:42 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Converter for sure.... Then get around to your gear swap. Then..... forget about the juice cams your currently considering. If you're into this deal as far as 3500 converters and 3.91 gears, then you should be thinking Solid lifter cam at the very least.
[Re: BSB67]
#962861
03/31/11 10:38 PM
03/31/11 10:38 PM
Posts: 164 mesa arizona
moturbopar
mesa arizona
I'm confused. Do you have a cam or not? You say you havent picked one but you spec a 268? Do you have a converter?
If you have the cam and converter, put it together and run it. You have a reasonable package already. Then you'll have better info for the next step.
If you don't have the cam, you could step it up and still be fine with the rest of the parts you have.
I guess it does sound confusing! I do have a cam and converter, xe268 and a 11" 2500-2800 stall converter. Do you guys think a hardened snout will hold up with a 100 shot? I guess I am paranoid about the small snout on the 904 converter.
