What octane really needed ? #962628
03/30/11 08:39 PM
03/30/11 08:39 PM
Nevada
theman440 Offline OP
Nevada
11.1 CR w/aluminum head (track only car)
Re: What octane really needed ? [Re: theman440] #962629
03/30/11 09:51 PM
03/30/11 09:51 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
id say 110 is more than good,mabey even 93 pump gas.
Re: What octane really needed ? [Re: theman440] #962630
03/30/11 10:18 PM
03/30/11 10:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the cam... when the intake closes it starts the
compression cycle
Re: What octane really needed ? [Re: MR_P_BODY] #962631
03/30/11 10:48 PM
03/30/11 10:48 PM
50/50 with 110 and sunoco 93 will be perfect.
Re: What octane really needed ? #962632
03/31/11 01:04 AM
03/31/11 01:04 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
In my 73 small block stroker.. 11:1 with Aluminum heads.. its 91 octane for the street.. 98-100-104 at the track...
260=ish duration, 108 LSA, 36 degrees timing, all in at 3000 rpm..
Re: What octane really needed ? [Re: theman440] #962633
03/31/11 02:28 AM
03/31/11 02:28 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
mix 4 gallons of 93 with 1 gallon of 110.
Re: What octane really needed ? [Re: qwkmopardan] #962634
03/31/11 03:12 AM
03/31/11 03:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know how you guys can suggest a certain octane
without knowing when the intake closes... hell if the
intake closes with the piston half way up the cylinder
he could pee in the tank and it would be fine....JMO
Re: What octane really needed ? [Re: MR_P_BODY] #962635
03/31/11 03:17 AM
03/31/11 03:17 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Ron
Re: What octane really needed ? [Re: MR_P_BODY] #962636
03/31/11 04:11 AM
03/31/11 04:11 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
A new grade of gas. pee85. He offered little info and what he told us: 11 to 1, aluminum heads and track only. You can bet it has a long dur. cam and intake is'nt closed 20deg A.B.C. It will probably run fine on 93 oct. but being at the track and 110 gas will be avail I suggest adding 20% 110 to be sure. If it detonates and pushes out the head gaskets try higher octane next time.
Re: What octane really needed ? [Re: qwkmopardan] #962637
03/31/11 09:44 AM
03/31/11 09:44 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run 93 on the street in my 440 with 12.5 domes and aluminum heads.Just cant really lay into it or it gets ping.If I mix 110 at about 50/50 its perfect.At the track I run mostly 110.Rocky
Chrysler Firepower
Re: What octane really needed ? [Re: qwkmopardan] #962638
03/31/11 10:20 AM
03/31/11 10:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The reason I said is I use to run 112 and dropped down
the octane and picked up ET... just by lowering the
octane... nothing else... and my cam is big duration
but a wide LSA
Re: What octane really needed ? [Re: MR_P_BODY] #962639
03/31/11 11:30 AM
03/31/11 11:30 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
A Mod with humor Anyhow... ya gota know where your intake closes to answer your question otherwise its like Mike said
Re: What octane really needed ? [Re: MR_P_BODY] #962640
03/31/11 11:35 AM
03/31/11 11:35 AM
Az
Crizila Offline
Crizila  Offline
Az
and thats not the only consideration, although pretty high on the list.
Fastest 300
Re: What octane really needed ? [Re: emarine01] #962641
03/31/11 11:38 AM
03/31/11 11:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
EX-mod
Re: What octane really needed ? [Re: MR_P_BODY] #962642
03/31/11 12:22 PM
03/31/11 12:22 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
EX-mod
Well that would explain the humor Oh... if ya dont know your cam specs, compression test and post the results
Re: What octane really needed ? [Re: qwkmopardan] #962643
03/31/11 04:46 PM
03/31/11 04:46 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
thats what i do.
