Re: What octane really needed ?
[Re: theman440]
#962630
03/30/11 10:18 PM
03/30/11 10:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
11.1 CR w/aluminum head (track only car)
Whats the cam... when the intake closes it starts the compression cycle
[Re: MR_P_BODY]
#962631
03/30/11 10:48 PM
03/30/11 10:48 PM
50/50 with 110 and sunoco 93 will be perfect.
[Re: qwkmopardan]
#962634
03/31/11 03:12 AM
03/31/11 03:12 AM
MR_P_BODY
I dont know how you guys can suggest a certain octane without knowing when the intake closes... hell if the intake closes with the piston half way up the cylinder he could pee in the tank and it would be fine....JMO
[Re: MR_P_BODY]
#962635
03/31/11 03:17 AM
03/31/11 03:17 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Ron
[Re: MR_P_BODY]
#962636
03/31/11 04:11 AM
03/31/11 04:11 AM
Posts: 883 Affton MO
qwkmopardan
Affton MO
A new grade of gas. pee85. He offered little info and what he told us: 11 to 1, aluminum heads and track only. You can bet it has a long dur. cam and intake is'nt closed 20deg A.B.C. It will probably run fine on 93 oct. but being at the track and 110 gas will be avail I suggest adding 20% 110 to be sure. If it detonates and pushes out the head gaskets try higher octane next time.
[Re: qwkmopardan]
#962637
03/31/11 09:44 AM
03/31/11 09:44 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I run 93 on the street in my 440 with 12.5 domes and aluminum heads.Just cant really lay into it or it gets ping.If I mix 110 at about 50/50 its perfect.At the track I run mostly 110.Rocky
Chrysler Firepower
[Re: qwkmopardan]
#962638
03/31/11 10:20 AM
03/31/11 10:20 AM
MR_P_BODY
The reason I said is I use to run 112 and dropped down the octane and picked up ET... just by lowering the octane... nothing else... and my cam is big duration but a wide LSA
[Re: MR_P_BODY]
#962639
03/31/11 11:30 AM
03/31/11 11:30 AM
Posts: 3,695 nc
emarine01
nc
A Mod with humor Anyhow... ya gota know where your intake closes to answer your question otherwise its like Mike said
[Re: MR_P_BODY]
#962642
03/31/11 12:22 PM
03/31/11 12:22 PM
Posts: 3,695 nc
emarine01
nc
[Re: qwkmopardan]
#962643
03/31/11 04:46 PM
03/31/11 04:46 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
mix 4 gallons of 93 with 1 gallon of 110.
thats what i do.
