valve lash hot/cold #962531
03/30/11 05:18 PM
03/30/11 05:18 PM
Newark, OH
springers340dart Offline OP
Newark, OH
gonna run the valves tonight but its snowin and mid 30 so i don't really wanna start it. if i have to i will but perfer not to. it says .010 I and .012 E hot. what should i set them at cold?? whats the adjustment differance about cold to hot?
Re: valve lash hot/cold [Re: springers340dart] #962532
03/30/11 05:20 PM
03/30/11 05:20 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
that lash seems tight.... block and head material are needed for you to get an answer really...
Mopar Performance
Re: valve lash hot/cold [Re: moparniac] #962533
03/30/11 05:25 PM
03/30/11 05:25 PM
Newark, OH
Newark, OH
thats what i thought when i put the cam in it last year but thats what the card calls for. sorry bout that did forget to mention that. cast heads.
Re: valve lash hot/cold [Re: springers340dart] #962534
03/30/11 05:32 PM
03/30/11 05:32 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
did it call for 10-12 thou cold ??? Give a call to that cam company and confirm that.. That might be a cold lash setting also.
I cant recall a solid roller cam ever being that tight on lash.. even tight lash cams are in the .018-.020 range.
If that was all aluminum wedge (Maxx Block) and Indy heads, you couldnt even achieve that those settings, if you wanted to. That tight of lash set hot would leave the valves open once it cooled... fact.... They grow about .015.. so it wouldnt even start once it cooled down.
I dont care what the cam card calls for I wouldnt run the tighter than .018-.020
Re: valve lash hot/cold [Re: Bob_Coomer] #962535
03/30/11 05:35 PM
03/30/11 05:35 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I bet its a cold setting... thats about right for a aluminum head big block with a cast iron block...
it would grow .006-.008 so you would be at the .018-.020 as mentioned.
Re: valve lash hot/cold [Re: Bob_Coomer] #962536
03/30/11 06:33 PM
03/30/11 06:33 PM
sg66mopar Offline
sg66mopar  Offline
Drag 'er down to Death Valley. It's 101 there right now. Perfect weather for runnin' valves.
Re: valve lash hot/cold [Re: springers340dart] #962537
03/30/11 07:33 PM
03/30/11 07:33 PM
IN
ahy Offline
ahy  Offline
IN
Different answer for cast iron heads or cast aluminum heads. Also, is it a cast iron block?
My setup is iron block and aluminum heads. I've checked both hot and cold. The "rule of thumb" that hot lash = cold lash + .005" with iron block/aluminum heads works well in my case.
Re: valve lash hot/cold [Re: springers340dart] #962538
03/31/11 12:58 AM
03/31/11 12:58 AM
Iron block with iron heads set them .002 looser when cold, per the Crane Cams catalog instructions for setting vavles when cold It works for me, check and reset them when hot
Re: valve lash hot/cold [Re: springers340dart] #962539
03/31/11 09:42 AM
03/31/11 09:42 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
FWIW I set mine at .012/.014 Stage VI heads Iron block solid roller cam and when I started it it sounds a little more nosiey than I thought it would. If we ever get some good weather I'm going to set them .016/.018 warm. 10/12 seems tight hot. What does the cam card recommend?
Coming soon!!!!
Re: valve lash hot/cold [Re: Mr.Yuck] #962540
03/31/11 11:01 PM
03/31/11 11:01 PM
Newark, OH
Newark, OH
.010 intake and .012 hot. lookin at the card right now. just set them tonight and it sounds great! cast 340 block and cast heads
Re: valve lash hot/cold [Re: springers340dart] #962541
04/01/11 10:22 AM
04/01/11 10:22 AM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Brian I always set mine at .020 cold. Make sure that both the Intake and Exhaust valves are on the base circle for an accurate setting. Hopefully we can get some warmer weather so the tracks can open up.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
