Re: HELP I need to clear an engine code 2001 caravan
[Re: modelmakerinc]
#962516
03/30/11 04:11 PM
03/30/11 04:11 PM
Posts: 21,492 It's a dry heat
gtx6970
It's a dry heat
Hey guys, I need the manner to clear a check engine light in my wifes 2001 3.3 l caravan. I cleaned and replaced a couple of sensors and the van is fine but I can't clear the code and it makes my wife nervous to drive any help is appreciated. Thanks
I don't remember the exact count right now but IF everythigng is repaired and operating as designed the code will clear itself in 'I think' 50 warm up cycles
[Re: gtx6970]
#962517
03/30/11 04:18 PM
03/30/11 04:18 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
50 ??? holy cow , I have an intermitent crank position censor in my 2000 Ram and I know it clears in less than 50 ???
[Re: JohnRR]
#962518
03/30/11 04:31 PM
03/30/11 04:31 PM
Posts: 4,958 WI
Dcuda69
WI
Does it clear or does the light just go off? Some codes will turn the light off after 3 warm up cycles w/no fault,but the code remains in history.Most codes will clear after 40 warm-ups(trips) with out a fault.
[Re: Dcuda69]
#962519
03/30/11 05:50 PM
03/30/11 05:50 PM
JohnRR
The light goes off, which is really what the OP wants to make the wife happy . If his light is not going off then he has not corrected the problem.
[Re: modelmakerinc]
#962521
03/30/11 06:02 PM
03/30/11 06:02 PM
JohnRR
Thanks guys, I guess time will tell if I fixed the problem if in a week or so the light doesnt go out or the van acts up again I'll have to go get the diagnosic tool. Henry
No autozone or advance auto nearby ? Sears has an Actron code reader , pocket size that just reads codes and will erase them for about 60 bucks .
