455 ci. Small Block #962447
03/30/11 02:37 PM
03/30/11 02:37 PM
HOUSTON,TEXAS
FIREGUY12 Offline OP
HOUSTON,TEXAS
Hey moparts. I have an engine I purchased from a member here on moparts. And wanted to know is there a better cylinder head I can purchase other than the B1/ BA M/C head that currently on it. The engine is 455ci
4.25 crank billet
4.125 bore
12-13:1 comp
620 roller
R3 siamese 59 degree block.
Dyno sheets states it made 630 H.P. 650 ft. lbs of torque.
I have not run it in my car but know I want more power in the near future. Will an Indy or W-9 head pick up horsepower level. I would like to see 750-800 H.P.
6557957-DNO+INFO.PDF (233 downloads)
Re: 455 ci. Small Block [Re: FIREGUY12] #962448
03/30/11 03:05 PM
03/30/11 03:05 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Id call Ryan J see what he says..
My good buddy runs a W2 iron head 420 inch engine... No dominator, no roller.. made 630hp on the dyno.... Runs 6.20's in the 8th mile at 108-110 mph in a mini tubbed dart with cal tracks.... about 2900-3000 lbs car.
So yea Id say there is power in there somewhere.. if he can make his run like that... You know those B1 heads can make a good amount more done right.
Clancy's car...
Re: 455 ci. Small Block [Re: Bob_Coomer] #962449
03/30/11 05:33 PM
03/30/11 05:33 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I think a set of 245 cnc indys would get you in the 750 range. I made 650 or so with them 422 12.0to 1 4150 950 hp carb and 662 roller.More cubes,cam,compression I wouldn't see why you couldn't make that kind of power.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 455 ci. Small Block [Re: Bob_Coomer] #962450
03/30/11 07:14 PM
03/30/11 07:14 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
6.2 eighth mile at 110 doesnt sound like 630hp in a 3000lb car or so Ive been told. mine runs 6.15 at 111 eighth mile at 2985 and people tell me that is only 550hp
Re: 455 ci. Small Block [Re: BLONDE BARRACUDA] #962451
03/30/11 07:30 PM
03/30/11 07:30 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
that moved center head should make way more than 630 horsepower, if that is what it is making now. i know ported they go around 350 cfm, as much or more than a big indy head. numbers are just numbers of course. That said, dont know much about that head, as not many are out there, but " in theory" it should make 700 horsepower easily. think they had like a 2.15 intake valve if i remember correctly. i know the much smaller b1ba head will make the kind of power this motor you are talking about currently, does.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 455 ci. Small Block [Re: BLONDE BARRACUDA] #962452
03/30/11 07:34 PM
03/30/11 07:34 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I think some one is telling you wrong my 416 with indybrocks push my 3000 ride to 6.2x's at 110-110 in the 1/8 and its been 9.76 at 138 1/4 and every calculator I have put the numbers in is right at 620 hp at the flywheel.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 455 ci. Small Block [Re: dusturbd340W5] #962453
03/30/11 07:39 PM
03/30/11 07:39 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Yep if anything I have heard his dyno is stingy....
And remember this
And E/T in some case (not all), mostly how eff the chassis is..
MPH is what to look at.
Re: 455 ci. Small Block [Re: Bob_Coomer] #962454
03/30/11 08:16 PM
03/30/11 08:16 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i dont think heads are the issue its the combo,UNLESS RAY CHARLES OR stevie wonder did the heads....there good biba mc's
Re: 455 ci. Small Block [Re: FIREGUY12] #962455
03/30/11 08:30 PM
03/30/11 08:30 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I put a saddle on it and take it to the track and see what it does before Id rip it apart.
Re: 455 ci. Small Block [Re: BLONDE BARRACUDA] #962456
03/30/11 09:09 PM
03/30/11 09:09 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The calculator on Wallace Racing puts you at 650-665 flywheel hp.
Re: 455 ci. Small Block [Re: justinp61] #962457
03/30/11 09:40 PM
03/30/11 09:40 PM
Wisconsin
Wisconsin
thanks for the input I appreciate it I thought 550 sounded a little low for a car running 9.70s
Re: 455 ci. Small Block [Re: fishy340] #962458
03/30/11 09:58 PM
03/30/11 09:58 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
LOL.. always good for a laugh..
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: 455 ci. Small Block [Re: FIREGUY12] #962459
03/30/11 11:33 PM
03/30/11 11:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
4.25 crank billet
4.125 bore
12-13:1 comp
620 roller
I have a couple of questions for ya... whats all the
specs on your cam and what do you turn this up to
(on the dyno since you havent run it yet)... those
are usually a nice head.... 620 lift really says nothing
Re: 455 ci. Small Block [Re: MR_P_BODY] #962460
03/30/11 11:39 PM
03/30/11 11:39 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I'd run it first..
If it were mine I would plug the lifter holes. Rebore and hone for 48 degree lifter angle.
Call CFE for the badest W8 he can put together for it.
Cause most of the guys who have these heads are not selling them off their engines. LOL
Re: 455 ci. Small Block [Re: Leon441] #962461
03/31/11 07:19 AM
03/31/11 07:19 AM
Finland
mafo Offline
mafo  Offline
Finland
That depends of course, how much is offered...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: 455 ci. Small Block [Re: BLONDE BARRACUDA] #962462
03/31/11 08:58 AM
03/31/11 08:58 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
That would be approx. your rear wheel horsepower.
Re: 455 ci. Small Block [Re: dusturbd340W5] #962463
03/31/11 10:42 AM
03/31/11 10:42 AM
San Diego
formula S Offline
formula S  Offline
San Diego
FWIW Those calculators give you average horse power on a pass, not peak
Re: 455 ci. Small Block [Re: 1967dartgt] #962464
03/31/11 10:44 AM
03/31/11 10:44 AM
HOUSTON,TEXAS
HOUSTON,TEXAS
I dont much about the cam specs. other than its suppose to be a 620 roller. I will definetly run it before i start tearing into the engine. If the dyno numbers are accurate then it should put my car in the 9.70 range or better. The dyno sheet is in the attachment of the first post.
Re: 455 ci. Small Block [Re: FIREGUY12] #962465
03/31/11 10:54 AM
03/31/11 10:54 AM
HOUSTON,TEXAS
HOUSTON,TEXAS
Sorry I cant get the dyno sheet to post but, it was pulled to 6500 rpm. made peak 634 H.P. at 5700 Rpm, 650 ft. lbs. torque at 4600 rpm.
6559643-DNO+INFO.PDF (114 downloads)
Re: 455 ci. Small Block [Re: FIREGUY12] #962466
03/31/11 04:49 PM
03/31/11 04:49 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
is that rwhp or flywheel? either way i agree with most blast it down the track 1st
