Re: 727 - pulls motor down on 2-3 shift
[Re: dOc …]
#960920
03/28/11 02:35 PM
03/28/11 02:35 PM
dartman366
Mt. Vernon, Ohio
Shift timing is waaay off.
What are the critical specs?
some time's you have to fudge the band adjustment a little to get it where it want's to be, is the band lever ratio the same as before? try backing off the band adjustment 1/4 to 1/2 turn and see if that help's,,if you tightened up the clutch running clearance then it engages before the band has released fully.
[Re: boscosis]
#960922
03/28/11 03:21 PM
03/28/11 03:21 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
Do you guys think it's a valvebody issue?
It's an issue CAUSED by the valvebody.
The 727 walks a very fine line on overlap , which is what you are seeing. The factory went to pains to make it as small as possible, when you increase line pressure, change clutch front pack clearance, change the lever ratio, change band adjustment and change spring count in the front drum you change that oh so delicate shift timing from the factory setting.
Now you have to deal with it. Playing with the band adjustemnt is the easiest way to try to fix it.
[Re: boscosis]
#960928
03/28/11 06:15 PM
03/28/11 06:15 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Thanks for the help guys; I'm considering finally building my own 727 along with my brother this time around. I've pulled them apart before but only to salvage parts like drums or planetaries. What manual/book do you guys recommend that I buy as a first-time "builder"?
One of the best 'books' I ever got came with a complete rebuild kit from Fairbanks transmissions - the instruction manual. Similar kits from B&M, etc. had virtually identical steps in them. I still refer to them when doing my 727's. Go to Mancini's - I think they sell one or more of the popular TF mod books...
http://chucker54.stores.yahoo.net/toatrha.html
[Re: Sixpak]
#960931
03/28/11 08:40 PM
03/28/11 08:40 PM
dartman366
Mt. Vernon, Ohio
the two best book's to have and will tell you a boat load of info and they are Torqueflite A-727 Transmission Handbook by Carl H, Munroe and the ATSG manual(automatic transmission service guide), I have both and they are indespensable. I do 904's but the 727 book still has a lot of pertinate info.
[Re: dartman366]
#960932
03/28/11 09:55 PM
03/28/11 09:55 PM
Posts: 3,106 Michigan
A727Tflite
You're not real clear with the problem at hand. You state that the trans almost locks up on the stands on the 2-3 shift, then you state it is lazy on the track. It's not uncommon to get overlap on the stands. What does it do on the track, run away on the 2-3 or overlap on the 2-3. What's lazy mean, it feels like it is slipping or not very quick to respond to the shifter movement? Watch the tach, if it jumps up on the 2-3 that's runaway, if the tach immediately drops and the car noses down on the shift that's overlap. Over lap means the front band hasn't come fully off before the front clutch has come on. Runaway means the band came off before the front clutch came on with sufficient capacity to pull the motor down. Any good valve body (A & A, Turbo Action, etc) out of the box installed in a properly built trans will not be off the mark, the rest is all timing. The number of front clutch springs vs. front band operating ratio and the front band release spring/s makes up the timing. Just the correct combination of parts. Believe it or not, go to the old Direct Connection manual, pick out the front clutch spring combination for your engine size, and match to the front servo release spring stack. You won't be disappointed. Remember, those packages were done by the engineers with only one motivation - make the Mopars as fast as possible.
[Re: John_Kunkel]
#960934
03/28/11 10:20 PM
03/28/11 10:20 PM
BradH
Easiest way to cure severe overlap is to place an orifice restrictor in the front clutch feed passage in the case. (circled in red below)
Remove the VB, tap the passage in the case to 1/8"-27 NPT and place a pipe plug with a drilled orifice in the case. I'd start with a .140" orifice.
I think this is what "LAR 414" mentioned doing to help fine tune the 2-3 shift, too. I think I need to try something like this...
