727 - pulls motor down on 2-3 shift #960915
03/28/11 02:19 PM
03/28/11 02:19 PM
boscosis Offline OP
super street
boscosis  Offline OP
super street
On jack stands you can tell that the motor lugs a little on the 2-3 shift; you almost see the tires stop turning briefly also. On the track the shift is lazy and the mph/et are not what they should be. This is a race-only 727 with a billet drum, bolt-in sprag, and a non low band apply A&A manual valve body.
What should we look for? This valve body has worked fine in a different tranny.
THanks
Re: 727 - pulls motor down on 2-3 shift [Re: boscosis] #960916
03/28/11 02:22 PM
03/28/11 02:22 PM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
what was the clearance in the high gear clutch pack? maybe to tight?
Re: 727 - pulls motor down on 2-3 shift [Re: boscosis] #960917
03/28/11 02:24 PM
03/28/11 02:24 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
Shift timing is waaay off.
What are the critical specs?
Re: 727 - pulls motor down on 2-3 shift [Re: dOc …] #960918
03/28/11 02:27 PM
03/28/11 02:27 PM
boscosis Offline OP
super street
boscosis  Offline OP
super street
I'm afraid that I didn't personally build the tranny so I don't know the clearances. Do you guys think it's a valvebody issue?
Re: 727 - pulls motor down on 2-3 shift [Re: boscosis] #960919
03/28/11 02:30 PM
03/28/11 02:30 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
Can you at least check line pressure ?
Re: 727 - pulls motor down on 2-3 shift [Re: dOc …] #960920
03/28/11 02:35 PM
03/28/11 02:35 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
some time's you have to fudge the band adjustment a little to get it where it want's to be, is the band lever ratio the same as before? try backing off the band adjustment 1/4 to 1/2 turn and see if that help's,,if you tightened up the clutch running clearance then it engages before the band has released fully.
Re: 727 - pulls motor down on 2-3 shift [Re: boscosis] #960921
03/28/11 02:39 PM
03/28/11 02:39 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
probably not,like I said before, band adjustment.
Re: 727 - pulls motor down on 2-3 shift [Re: boscosis] #960922
03/28/11 03:21 PM
03/28/11 03:21 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It's an issue CAUSED by the valvebody.
The 727 walks a very fine line on overlap , which is what you are seeing. The factory went to pains to make it as small as possible, when you increase line pressure, change clutch front pack clearance, change the lever ratio, change band adjustment and change spring count in the front drum you change that oh so delicate shift timing from the factory setting.
Now you have to deal with it. Playing with the band adjustemnt is the easiest way to try to fix it.
Re: 727 - pulls motor down on 2-3 shift [Re: boscosis] #960923
03/28/11 03:43 PM
03/28/11 03:43 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Easiest way to cure severe overlap is to place an orifice restrictor in the front clutch feed passage in the case. (circled in red below)
Remove the VB, tap the passage in the case to 1/8"-27 NPT and place a pipe plug with a drilled orifice in the case. I'd start with a .140" orifice.
Re: 727 - pulls motor down on 2-3 shift [Re: John_Kunkel] #960924
03/28/11 04:54 PM
03/28/11 04:54 PM
boscosis Offline OP
super street
boscosis  Offline OP
super street
Thanks for the help guys; I'm considering finally building my own 727 along with my brother this time around. I've pulled them apart before but only to salvage parts like drums or planetaries.
What manual/book do you guys recommend that I buy as a first-time "builder"?
Re: 727 - pulls motor down on 2-3 shift [Re: boscosis] #960925
03/28/11 05:58 PM
03/28/11 05:58 PM
Cab_Burge Online work
Cab_Burge  Online Work
The problems your describing are common when the shifter linkage is not adjusted correctly Make sure the shifter cable end drops into the shifter arm attached to the valve body easily in all three forward gears as well as nuetral Put the car up on jackstands and disconnect the shifter cable, start the car and shift the tranny manually from underneath the car at 1500 to 2500 RPM and see if it does the same as before, if not it is the linkage Let us know what you find out
Re: 727 - pulls motor down on 2-3 shift [Re: Cab_Burge] #960926
03/28/11 06:07 PM
03/28/11 06:07 PM
boscosis Offline OP
super street
boscosis  Offline OP
super street
Shifter alignment is perfect so I'm pretty confident that isn't the problem.
Re: 727 - pulls motor down on 2-3 shift [Re: John_Kunkel] #960927
03/28/11 06:10 PM
03/28/11 06:10 PM
NC
440Jim Offline
440Jim  Offline
NC
Just to add to the good advice given,
if that trans has a 5.0 front band lever, take it out and put a 3.8 or 4.2 ratio lever in.
Re: 727 - pulls motor down on 2-3 shift [Re: boscosis] #960928
03/28/11 06:15 PM
03/28/11 06:15 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
One of the best 'books' I ever got came with a complete rebuild kit from Fairbanks transmissions - the instruction manual. Similar kits from B&M, etc. had virtually identical steps in them. I still refer to them when doing my 727's. Go to Mancini's - I think they sell one or more of the popular TF mod books...
http://chucker54.stores.yahoo.net/toatrha.html
Re: 727 - pulls motor down on 2-3 shift [Re: 440Jim] #960929
03/28/11 06:28 PM
03/28/11 06:28 PM
organ
maximum entropy Offline
organ
yeah, that 5.0 lever is a killer. anything you can do to speed up the release of the intermediate band, is going to make it easier to nail down the 2-3 shift timing. a billet servo with heavy duty release springs is a good step.
Re: 727 - pulls motor down on 2-3 shift [Re: boscosis] #960930
03/28/11 08:14 PM
03/28/11 08:14 PM
Nevada
theman440 Offline
theman440  Offline
Nevada
How does it shift at WOT ?
Re: 727 - pulls motor down on 2-3 shift [Re: Sixpak] #960931
03/28/11 08:40 PM
03/28/11 08:40 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
the two best book's to have and will tell you a boat load of info and they are Torqueflite A-727 Transmission Handbook by Carl H, Munroe and the ATSG manual(automatic transmission service guide), I have both and they are indespensable. I do 904's but the 727 book still has a lot of pertinate info.
Re: 727 - pulls motor down on 2-3 shift [Re: dartman366] #960932
03/28/11 09:55 PM
03/28/11 09:55 PM
A727Tflite Offline
A727Tflite  Offline
You're not real clear with the problem at hand. You state that the trans almost locks up on the stands on the 2-3 shift, then you state it is lazy on the track. It's not uncommon to get overlap on the stands. What does it do on the track, run away on the 2-3 or overlap on the 2-3. What's lazy mean, it feels like it is slipping or not very quick to respond to the shifter movement? Watch the tach, if it jumps up on the 2-3 that's runaway, if the tach immediately drops and the car noses down on the shift that's overlap. Over lap means the front band hasn't come fully off before the front clutch has come on. Runaway means the band came off before the front clutch came on with sufficient capacity to pull the motor down. Any good valve body (A & A, Turbo Action, etc) out of the box installed in a properly built trans will not be off the mark, the rest is all timing. The number of front clutch springs vs. front band operating ratio and the front band release spring/s makes up the timing. Just the correct combination of parts. Believe it or not, go to the old Direct Connection manual, pick out the front clutch spring combination for your engine size, and match to the front servo release spring stack. You won't be disappointed. Remember, those packages were done by the engineers with only one motivation - make the Mopars as fast as possible.
Re: 727 - pulls motor down on 2-3 shift [Re: A727Tflite] #960933
03/28/11 10:09 PM
03/28/11 10:09 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
Lucian Mancini
..... part of that Highland Park and CTC "family" ? ..
Re: 727 - pulls motor down on 2-3 shift [Re: John_Kunkel] #960934
03/28/11 10:20 PM
03/28/11 10:20 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I think this is what "LAR 414" mentioned doing to help fine tune the 2-3 shift, too. I think I need to try something like this...
